Using Siebel Tools > Managing Repositories > Upgrading Repositories >
Identifying Conflicts That Occur During Upgrades
This topic describes how to identify merge conflicts between objects that Siebel Tools added or modified during a repository merge. A merge conflict is a scenario in which a customer changed an object in the current customer repository, and Siebel CRM changed that same object to a different value in a new version of the Siebel repository. Consequently, the attribute for the object is different when the following three repositories are compared: the current customer repository, the current Siebel repository, and the new version of the Siebel repository. To identify conflicts that occur during upgrades
- Make sure you finish upgrading repositories.
For more information, see Upgrading Repositories.
- In Siebel Tools, click the Screens menu, Application Upgrader, and then click Application Upgrade Object List.
- In the Application Upgrades list, right-click the record of the merge that you want to analyze, and then click Hierarchy Reports.
Siebel Tools displays the hierarchy report, which includes the objects that Siebel Tools added or modified during a merge. The report includes the following types of objects:
- Objects that include a valid value for each field value. Siebel Tools modified these objects during the merge. An N or a Y in a binary field is an example of a valid value.
For these objects, the Status field designates added objects or objects with modified attributes. For added objects, an N appears in the Attributes field because none of the attributes are modified. For objects with modified attributes, a Y appears in the Attributes field, and the modified attributes appear in the Attributes pane.
- Objects that include an asterisk (*) for each field value. Siebel Tools modified children of these objects during the merge, or Siebel Tools modified dependent objects of these objects during the merge.
- To view information about merge details, complete the following steps:
- Expand and navigate through the hierarchical tree in the Object Types pane to select a parent or child object type.
The top List of Objects pane shows the objects for the parent object type that you select, and the bottom List of Objects pane shows the objects for the child object type that you select.
- Click an object in a List of Objects pane.
In the Attributes pane, Siebel Tools displays any merge conflicts for the object.
- (Optional) To filter the objects in the report, select one of the following values in the Filter drop-down list, and then click Go:
- Siebel and Customer Modified. Siebel Tools displays only objects that Oracle or you modified. These objects have a Y in the In Prior Standard, In Prior Customized, and In New Standard fields.
- Siebel Modified. Siebel Tools displays only objects that Oracle modified or added. These objects have an N in the In Prior Standard and In Prior Customized field and a Y in the In New Standard field.
- All. Siebel Tools displays all modified or added objects.
- (Optional) To filter the merge conflicts in the Attributes pane, select or clear the Critical Only check box as follows, and then click Go:
- Select the check box to show only critical merge conflicts.
- Clear the check box to show all merge conflicts.
- (Optional) To display the dependencies for an object, complete the following steps:
If you want to display the dependencies for an additional object, then hold down the CTRL key, and click the additional object in the List of Objects pane.
- Click Show Dependencies.
If the object has no dependencies, then the Show Dependencies button is disabled.
Siebel Tools displays the dependent objects that it modified and the attributes for these objects.
- Click Back to return to the hierarchy report.
