Using Siebel Tools > Managing Repositories > Process of Migrating Repositories > Updating Siebel Remote DatabasesIf your environment includes Remote users, then you must update Siebel Remote databases. For more information about performing the steps in this topic, see Siebel Remote and Replication Manager Administration Guide. This task is a step in Process of Migrating Repositories. To update Siebel Remote databases
Using Siebel Anywhere to Update Remote DatabasesYou can use Siebel Anywhere to update some Remote databases. Importing a repository and then synchronizing the schema definition in a target environment is equivalent to migrating the repository. The Remote users must synchronize the next time they log in to their local database after the migration finishes. Synchronizing downloads new schema modifications from the Siebel Server to the local database that the Remote user uses. Before synchronization occurs, you must rename the older repository to a temporary name, and rename the imported repository to the correct name. If a Remote user does not synchronize, then the data that the local database contains does not match the data that the server database contains. For more information, see Siebel Anywhere Administration Guide. |
| Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
