Using Siebel Tools > Using Siebel Tools > Using Menus and Running Queries >
Using a Right-Click Menu
A right-click menu is a type of context-sensitive menu that appears if you right-click an object or an element. It allows you to do the following:
  • Create, copy, or delete a record.
  • Undo modifications that you make to a record.
  • Open the Applet Layout Editor or the View Layout Editor from the Object List Editor. You right-click an applet or a view, and then click Edit Web Layout.
  • View and edit a Web template. You right-click a Web template in the Object List Editor, and then click View Web Layout.
  • Display the name and status of a toolbar. You can right-click any toolbar. You can also customize how a toolbar appears.
  • Check out or lock an object.
  • Add an object to an archive.
  • Access wizards.
Using Siebel Tools Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices.
