Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars > Using the Properties WindowThe Properties window is a window that displays the properties and the property value for the object that you choose in the Object List Editor. It displays the name of this object near the top of the window. It displays the name of the property in the left column, and the property value in the right column. Siebel Tools displays properties in the Properties window in alphabetic order. You can click the Categorized tab to view these properties grouped according to category. The Properties window does not display the Project property or the Changed property. In this example, you use the Properties window to modify the Comments property of the Siebel Call Center application.
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
