Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars > Using the Multi Value Property WindowThe Multi Value Property Window allows you to view and set values for multi-value properties when you use one of the following designers: For more information about multi-value properties and how to use the Multi Value Property Window, see Siebel Business Process Framework: Task UI Guide and Siebel Business Process Framework: Workflow Guide. |
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
