Using Siebel Tools > Using Siebel Tools > Using Windows, Wizards, and Toolbars > Using a New Object WizardA new object wizard is a feature that you can use that guides you through the steps of creating a new object. It prompts you to configure the properties and objects that Siebel Tools requires according to the object type that you are creating. You can use a new object wizard to create the following objects:
For more information about how to use a wizard for a particular object type, see Configuring Siebel Business Applications. |
Using Siebel Tools | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
