Using Siebel Tools > Using Siebel Tools > Using the Object Explorer and Object List Editor >
Displaying Object Types in the Object Explorer
This topic describes how to display object types in the Object Explorer. To display object types in the Object Explorer
- Log in to Siebel Tools.
- Click the View menu, and then click Options.
- Click the Object Explorer tab.
- Scroll down through the Object Explorer Hierarchy window until you locate the object type you want to display.
- Make sure the object type you want to display includes a check mark, and use the values from the following table.
Display this object and all child objects of this object. |
Hide this object and all child objects of this object. |
Display this object. Display some child objects and hide some child objects. |
If you add a check mark to a top-level object type, such as Applet, then Siebel Tools adds a check mark to all child objects that the Applet contains. You can expand the parent tree to display only some child objects. A top-level object type is an object type at the top of the object hierarchy. The object types that the Object Explorer shows immediately after you install Siebel Tools, but before you expand any object types in the Object Explorer, are top-level object types.
- (Optional) To restore the Object Explorer to the settings when you first install Siebel Tools, click Default.
- Click OK.
Displaying Hidden Object Types and Properties
This topic describes how to display hidden object types and properties. A hidden object type is an object type that Siebel CRM does not show in the Siebel Web Client. For more information, see Siebel Object Types Reference. To display hidden object types and properties
- Close Siebel Tools.
- Use a text editor to open the
tools.cfg file.
For more information, see About the Configuration Files.
- In the Siebel section, set the value of the following parameter to
All:
ClientConfigurationMode
- Save the file, and then restart Siebel Tools.
