Siebel eSales Administration Guide > Integrating Siebel eSales with Third-Party Payment Applications > Customizing Cybersource Integration >
Passing Data from Other Fields in the Siebel Database
You can add data fields to those passed to CyberSource. For more information on modifying integration objects, see Integration Platform Technologies: Siebel Enterprise Application Integration. For more information on modifying scripts, see Using Siebel Tools. To add a data field
- In Siebel Tools, add the field to the appropriate Cybersource input and output integration objects.
- Modify the (declarations) script in the CyberSource Adapter Service business service to add the field to the correct output object, for example ICS2OBJS["Authorization"].OutputFields.
- In your Siebel Business Application, navigate to Integration Administration > Data Map Editor.
- Update the data map so that data from the appropriate Siebel field will be passed to the CyberSource integration object.
