Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Managing Calendars
Administrators define Calendars, which are associated with ARM Periods and Organizational Units. One Period may have many Calendars, to reflect different date configurations for the period; an Organizational Unit is assigned a single Calendar that determines the dates used for that Organizational Unit. Calendars must exist first; in System Settings, an Administrator assigns a calendar to an Account Reconciliation Period or to an Organizational Unit.
Adding Calendars
To add calendars:
  1. In Account Reconciliation, select Manage, and then System Settings. In System Settings, select Calendars.
  2. Click Actions, and then New.
  3. Populate these fields:
    • Calendar ID
      Required as an Oracle Hyperion Enterprise Performance Management System Lifecycle Management identifier and must be unique.
    • Name
      Required.
Deleting Calendars
To delete calendars:
  2. Select a calendar, Actions, and then Delete.
    The BASE calendar cannot be deleted.
