Tokens in Account Reconciliation:
Must be unique
Cannot be modified
Should not be deleted. When you try to delete, a warning message is displayed: "Deleting a Global Integration Token will invalidate the URLs that are referencing it. Are you sure you want to continue?"
To create a token:
