Holiday Rule ID
This is the attribute that will uniquely identify the record for LCM purposes. Holiday Rule ID is mandatory and must be unique.
Name
Can be up to 50 characters. Uniqueness is not required.
Year
The Year attribute behaves as a filter option. Users need not select a value for this attribute. If they do, then the table should be filtered to display the dates associated with the selected year.
