To add an organization:
Name
Administrators can change the name, and it need not be unique.
Organizational Unit ID
A unique ID used to identify the transaction for Oracle Hyperion Enterprise Performance Management System Lifecycle Management purposes. Organizational Unit ID cannot be changed after an organizational unit is set.
Optional: Description
Time Zone
Determines which time zone applies to the organizational unit. Selection of a time zone is optional. If a time zone is not selected, the task time zone will revert to the user’s time zone. See Supported Time Zones in Organization Units.
Holiday Rule
Determines which list of holidays applies to the organizational unit. Selection of a Holiday Rule is optional. See Managing Holiday Rules for Close Manager.
Parent Organizational Unit
Enables Administrators to change the hierarchy.
Work Days
Determines which days of the week are work days.
To select a user:
