Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Deleting a Connection
You cannot delete a connection if the connection is used as part of the integration definition or if it is used in data mapping for posting. See Defining Integrations.
To delete a connection:
  1. In your application select Manage, and then System Settings. In System Settings, select Connection, and then select a connection.
  2. Select Actions, and then Delete.
  3. Click Yes to the question, "Are you sure you want to delete (connection name)."
