Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Deleting Custom Currencies
To delete custom currencies:
  1. In your application select Manage, and then System Settings. In System Settings, select Currencies.
  2. Select a currency, then Actions, and then Delete.
    You cannot delete the following currencies:
    • A standard currency. It is always locked.
    • An enabled currency. Disable the currency before deleting it.
    • If a currency is in use, an error message tells you where it is used and prevents you from deleting it.
  3. Click OK.
