Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Disabling Standard Currencies
Standard currencies are installed with the product. If you want to disable unused currencies on available currency lists, disable them in the Currency System Settings.
To disable standard currencies:
  1. In your application select Manage, and then System Settings. In System Settings, select Currencies.
  2. Select a currency, and then clear Enabled.
