Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Deleting Frequencies
You can delete frequency if they are not used in the period.
To delete frequency:
  1. In your application select Manage, and then System Settings. In System Settings, select Frequency.
  2. Select a frequency and select Actions, and then Delete.
    If the frequency is in use by other items, it cannot be deleted and the Delete button is disabled.
