Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Creating Periods
To create a Period:
  1. In your application select Manage, and then System Settings. In System Settings, select Period.
  2. Click Actions, and then New.
  3. Enter:
    • Start Year
      The Start Year of one period cannot overlap the End Date of a previous period.
    • Number of Years, the maximum number of years is 20
    • Period Name, the maximum characters is 80
      You can use special characters; example: 02/15/2015.
    • Description, the maximum characters is 1000
    • Frequency
      You can specify which frequencies are used in each period by selecting the frequencies from the list of defined frequencies. See Creating Frequencies
