Go to primary content
Oracle® Hyperion Financial Close Management Administrator's Guide
E91357-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Defining Preferences
To define preferences:
  1. In your application select Manage, and then System Settings. In System Settings, select Preferences.
  2. To define Number Format, select the Decimal Places and the Negative Number display; for example: -1,234 or (1234).
  3. Define Cell Format.
