1. Preface
1.1 Introduction
This manual is designed to help you analyse the customer’s economic depenendecy by generating reports during the credit appraisal management process.
1.2 Audience
This manual is intended for the Customer Service Representatives (CSRs) and staff in charge of setting up new products in your bank.
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Acronyms and Abbreviations
The following are some of the acronyms and abbreviations you are likely to find in the manual:
Acronym Description
ELCM Enterprise Limits and Collateral Management
System/the system Oracle FLEXCUBE system (unless otherwise specified).
1.5 Organization
This manual is organized as follows:
Chapter Description
Chapter 1 About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual
Chapter 2 Reports lists the possible reports that can be generated for the module.
Chapter 3 Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.6 Related Documents
1.7 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons Function
  Exit
  Add row
  Delete row
  Option List
