This manual is designed to help acquaint you with the interface between Oracle FLEXCUBE and the other systems within your bank.
This manual provides you extensive explanations about the various maintenances required for the smooth exchange of data between Oracle FLEXCUBE and the applicable systems through the interface. It also gives you an insight into the processes involved in the actual exchange of data.
This manual is intended for the following User/User Roles:
Role | Function | ||
Back office data entry Clerks | Input functions for maintenance related to the interface. | ||
Back office Managers/Officers | Authorization functions. |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
Chapter | Description | ||
Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
Chapter 2 | The Oracle FLEXCUBE EMS Interface explains about the EMS (Electronic Messaging Service) interface between external systems and Oracle FLEXCUBE. | ||
Chapter 3 | Maintaining Interface specific Details deals with the maintenance of various customer account transactions through EMS. | ||
Chapter 4 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
Abbreviation | Description | ||
System | Unless and otherwise specified, it shall always refer to Oracle FLEXCUBE system |
This User Manual may refer to all or some of the following icons.
Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
