This user guide deals with the Oracle FLEXCUBE Information Server. The Oracle FLEXCUBE Information Server facilitates reporting of analysable data that helps improved decision making. The maintenances required for the proper functioning of the system and the processing related to it are covered in this manual.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office data entry Clerks | Input functions for maintenance related to the interface | ||
| Back office Managers/Officers | Authorization functions | ||
| Higher Level Management | Analyse business performances |
| Abbreviation | Description | ||
| System | Unless specified, it shall always refer to Oracle FLEXCUBE | ||
| NPA | Non Performing Assets | ||
| EOFI | End of Financial Input | ||
| RPD | Repository Definition File | ||
| CA | Current Accounts | ||
| SB | Savings Bank Account | ||
| TD | Term Deposits | ||
| OD/CC | Over Draft/Cash Credit | ||
| SME | Small and Medium Enterprises | ||
| TD(P) | Term Deposit (Principal) | ||
| TD(I) | Term Deposit (Interest) | ||
| TD(P+I) | Term Deposit (Principal + Interest) | ||
| MIS | Management Information System | ||
| ACY | Account Currency | ||
| LCY | Local Currency | ||
| MTD | Month to Date | ||
This manual is organized into the following chapters:
| Chapter | Description | ||
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Oracle FLEXCUBE Information Server discusses about the features which are to be maintained in Oracle FLEXCUBE for enterprise reporting. | ||
| Chapter 3 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
You may refer the following manuals for more information:
This User Manual may refer to all or some of the following icons:
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
Refer the Procedures User Manual for further details about the icons.
