This manual is designed to help you quickly acquaint yourself with the Islamic Accounts module of Oracle FLEXCUBE. It provides information on creating Islamic accounts in Oracle FLEXCUBE.
You can obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office managers/officers | Authorization functions | ||
| Product Managers | Product definition and authorization | ||
| End of day operators | Processing during end of day/ beginning of day | ||
| Financial Controller/Product Managers | Generation of reports |
This manual is organized into the following chapters:
| Chapter | Description | ||
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Creating Islamic Accounts explains how you can create Islamic Deposit Accounts. | ||
| Chapter 3 | Maintaining Investment Weights explains to process to capture the risk associated with every investment to compute the profit distribution. | ||
| Chapter 4 | Creating Islamic Term Deposits describes the process to setup and maintain term deposit account facilitated by Oracle FLEXCUBE. | ||
| Chapter 5 | Reports provides a list of reports that can be generated in this module and also explains their contents. | ||
| Chapter 6 | Annexure A - IP Rule Set-up lists the Profit and Charge (IP) rules which are to be maintained for the Islamic TD module of Oracle FLEXCUBE. | ||
| Chapter 7 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. | ||
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
