This manual is designed to help acquaint you with the Expense Processing Module of Oracle FLEXCUBE. It provides an overview of the module and guides you, through the various steps involved in processing expenses.
You can further obtain information about to a particular field by placing the cursor on the relevant field and striking the <F1> key on the keyboard.
This manual is intended for the following User/User Roles:
Role | Function | ||
Back office data entry clerk | Input functions for contracts. | ||
Back office managers/officers | Authorization functions. | ||
Product Managers | Product definition and authorization. | ||
End of Day operators | Processing during End of Day/ Beginning of Day. | ||
Financial Controller / Product Managers | Generation of reports. |
This manual is organized into the following chapters:
Chapter | Description | ||
Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual | ||
Chapter 2 | Expense Processing – An Overview gives a brief introduction to the module and its features. | ||
Chapter 3 | Maintaining Documents and Vendors explains the maintenance you need to do before you begin operations on this module. | ||
Chapter 4 | Defining Attributes Specific to an XP Product talks about defining the attributes specific to setting up an XP product. | ||
Chapter 5 | Processing an Expense Contract deals with the procedure involved in entering the details of an XP transaction. | ||
Chapter 6 | Reports provides a list of reports that can be generated in this module and also explains their contents. | ||
Chapter 7 | Appendix A - Accounting Entries and Advices for the Expense Processing module contains a list of suggested accounting entries and advices for the module. | ||
Chapter 8 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
You may need to refer to any or all of the User Manuals while working on the XP module:
This User Manual may refer to all or some of the following icons.
Icons | Function | ||
Exit | |||
Add row | |||
Delete row | |||
Option List |
