Primavera P6 Administrator Setup Tasks
Primavera P6 Administrator is the primary application which system administrators use to review, modify, add, and delete P6 EPPM configurations. P6 EPPM configurations are stored in the database that you specified when you installed P6. These configurations contain all of the settings used to run the application server for P6.
Caution: Many of the defaults are set to maximize the performance of your database. You should change them only if you are certain a change is needed.
In This Section
What's Changed
Launching the Primavera P6 Administrator
About the P6 EPPM System Administration Guide
Reviewing and Modifying Configurations for P6
About the Configurations Tab in the Primavera P6 Administrator
Authentication in P6 EPPM
Legal Notices
Copyright © 1999, 2016, Oracle and/or its affiliates. All rights reserved.
Last Published Friday, April 15, 2016
