Field |
Definition |
A user with full authority to all Order Broker screens, including the Tenant - Cloud screen, which includes configuration options related to cloud administration. You cannot delete this user. |
Key metrics for product locations. Possible attributes are Daily Sell Through Quantity, Sell Quantity/Multiple, Minimum Sell Quantity, Shrink Rate %, and Sales Velocity. Probability rules can use attributes as part of their calculations. For example, you might want to set up a probability rule that specifies to reduce the available quantity displayed in locate items search results by the daily sell-through quantity for a location in an offline system. |
An inbound message to increase, decrease, or reset the current available quantity for a product location without using the import process. See the Operations Guide for more information. |
The available quantity from the product location minus the reserved quantity and any stc_fulfilled_quantity (displayed on the Product Location screen as the Fulfilled Quantity). |
A retail brand associated with an organization to identify the organization to customers receiving drop shipments. The brand logo prints on the pack slip and pullsheet when the vendor generates these PDF documents. Each organization using the Supplier Direct Fulfillment module must have at least one brand. |
box |
The dimensions of a box used to ship one or more items using an integrated shipping system. You can define whether the box is available in the Supplier Direct Fulfillment module, Store Connect module, or both. The dimensions of the box used with each shipment is required for all delivery orders and purchase orders using an integrated shipping system. |
calculation |
A mathematical expression that you can include in a probability rule. For example, you might include a calculation such as Next PO Quantity Minus [-] Daily Sell Through in a probability rule. Created how? You can create and work with calculations at the Calculations window. See that window for more information. |
carrier |
A ship via that your vendors use to deliver drop ship orders to customers or that a store associate can use to confirm shipment of delivery orders in Store Connect. Required for all sales orders and purchase orders. |
category |
See location category. |
The message submitted by the retailer to create a new purchase order in Order Broker and assign the purchase order to a vendor. |
The message submitted by the retailer to create a new vendor in Order Broker, or to update an existing vendor. |
CSV file |
A comma-separated file. Order Broker: • Proximity upload: You need to upload a postal code file in this format and use the Proximity Uploads screen to populate or update the proximity location table. See Proximity upload process overview for more information. Supplier Direct Fulfillment: • Pack slip: When the vendor uses the Vendor Portal to generate pack slips for purchase orders, the vendor can generate a CSV file containing the pack slip information, either instead of or in addition to a PDF file. • Shipment upload: The vendor can use a CSV file to confirm shipments of purchase orders. • Invoice upload: The vendor can use a CSV file to create invoices. |
default Store Connect system |
The system that is available for order processing through the Store Connect module. There can be only one Store Connect default system in an organization. Defined by the Store Connect Default flag at the System screen. This flag controls whether: • you can assign store associate user profiles to the locations associated with the system, so they can log in and process orders through the Store Connect screens • to include the locations for the system in the settings you set up through the Store Connect Preferences screen, such as the schedule to update assigned orders from New Order to Polled status • to generate an email notification to the store when new orders are polled • to generate pickup-ready notification emails for pickup orders or shipment notification emails for shipped delivery orders • the Fulfilled Inv Export tab is available at the System screen, so you can run the Fulfilled Inventory Export to the system, and whether to include each product location in the export • to track the Fulfilled Quantity for each product location, and reduce this quantity when you run the inventory export |
The primary system for a organization. Products in Order Broker can have relationships with every integrated system, but they are defined by the default system. You should load the Order Broker database with the default system’s products first, and then create system products for each additional integrated system. Created how? A default system is identified by the Default flag at the Systems screen. You set this flag by selecting the Organization Default checkbox at the System screen. For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including systems. |
The location where the Routing Engine assigns an order if it is unable to find an actual location to fulfill the order or line. The Routing Engine uses the Order Broker Settings at the Preferences screen, or overrides specified through the Order Broker Preference Overrides screen, to determine which locations to select to fulfill an order or line, and the Search Retries setting at this screen to determine the number of times to reassign an order or its individual lines after rejection by a fulfilling location. |
The system within an organization that is associated with any vendors. Order Broker identifies the default vendor system by the Vendor Default flag. Required to create vendors: You cannot create a vendor for an organization until you create the default vendor system. This system should not represent an actual system that integrates with Order Broker. No additional information required: It is not necessary to specify any additional information for the default vendor system besides entering the Name and selecting the Vendor Default flag. Only one default per organization: There can be only one default vendor system for an organization. If you select the Vendor Default flag for an additional system, the flag is cleared for the current default vendor system. Automatically creates vendor location type: When you create the default vendor system, Order Broker automatically creates a the DS Vendor location type. This location type is also required to create vendors. You should not delete this location type. |
An order to be shipped to the customer from one or more locations selected by the Routing Engine or specified in the submit order message. See Delivery Order for more information. |
discovery messages |
The discovery web services provide a means to request a listing of systems or locations from Order Broker. See the Operations Guide for more information. |
The location type identifying drop ship vendors. Order Broker automatically creates this location type when you create the default vendor system for your organization. This location type is required for you to create drop ship vendors. Identifying the DS Vendor location type: Order Broker creates this location type with: • Type = DS Vendor • Name = Drop Ship Vendors • Category = Drop Ship Vendor Important: You should not delete this location type. |
When you use the Routing Engine, this is the location (warehouse or store): • pickup or ship-to-store order: where the customer is picking up the order • delivery order: that is shipping the order or lines to the customer • retail pickup order: that is transferring the inventory the originating location Note: An integrated system might use the term “fulfilling location” differently. For example, Order Management System uses this term to designate the location that originates a ship-to-store order rather than the location where the customer picks it up. |
A message sent to the Routing Engine from a location or system, requesting information on any orders or lines assigned to the location, or locations associated with the system, for fulfillment. See The Routing Engine for an overview. |
The message submitted by the retailer to request a listing of purchase order activity since the last getDSChanges request was processed. The response message includes information on activities such as status changes and shipments. Part of the Supplier Direct Fulfillment module. |
The message submitted by the retailer to request details on any invoices posted by the vendor since the last getDSInvoices request was processed. Part of the Supplier Direct Fulfillment module. |
The message submitted by an integrated vendor to request new purchase orders. Typically triggered by the launchDSOrders (nudge) message from Order Broker. See Vendor Integration for background, and see the Vendor Integration Guide for details. |
The message submitted by an integrated vendor to confirm shipment of a purchase order. See Vendor Integration for background, and see the Vendor Integration Guide for details. |
The Group Shipment Locations setting at the Preferences screen controls how the locate items response works for delivery or retail pickup requests: • If the Group Shipment Locations preference is unselected, the response message lists locations where the available quantity should be able to fulfill the order. • If the Group Shipment Locations preference is selected, the Routing Engine uses the same logic as when the preference is unselected; however, the response does not include details on each location that can fulfill the order. Instead, the response just includes the virtual (non-existent) location, indicating that the order can be fulfilled through the Routing Engine. For more information: See Selecting a Location for a Delivery or Retail Pickup Order for a discussion. |
A unique ID number assigned by Order Broker to identify a product and product location import. See Importing Items/Products, Inventory, Barcodes, and Locations into the Order Broker Database for an overview. Part of the Routing Engine module. |
A process to import new or updated locations, products and system products, product locations, and product barcodes from an integrated system into Order Broker for the Routing Engine. In order to import, you need to use the System Import Schedule screen to schedule regular imports of new or updated products and product locations, or to run the import on demand. For more information: See Importing Items/Products, Inventory, Barcodes, and Locations into the Order Broker Database for background. |
IN PROCESS location |
The temporary virtual location where the Order Broker assigns retail pickup or delivery orders at initial creation before selecting an actual fulfilling location, if no fulfilling location is specified in the submit order request. This location is created automatically, and: • is assigned to the organization’s default system • is assigned to the same location type as the organization’s Default Unfulfillable Location • has all Fulfillment settings at the Preferences screen (Pickup Available, Delivery Available, Retail Pickup Available, Backorder Available, and Ship To Store Available) set to No Used only if the Acknowledge Order Before Brokering preference is selected. |
A vendor who uses XML and JSON messages, rather than Vendor Portal screens, to receive purchase orders and confirm shipments. See Vendor Integration for an overview, and the Vendor Integration Guide for details. |
A request for product availability sent by Order Broker to an online system, in order to respond to a locate items request. For more information: See The Routing Engine for a process overview. |
The Type for a probability location assignment. The inventory level type provides a means to apply rules differently based on how recently you received an inventory update for the product location. Possible types are: • On-line only: The product location is within an online system, and you have received an inventory inquiry response for the product location. • Off-line only: You have not received an inventory update within the time period specified at the Preferences screen. Even if the product location is within an online system, it is considered off-line for the purposes of probability rule evaluation if you have not received an inventory inquiry response (if, for example, the location is having communication difficulties, or if the process responsible for inventory inquiry requests and responses is not running). • Both: Evaluate the rule for the product location, regardless of whether the product location is processing inventory inquiry responses. Used by the Routing Engine module. |
Possible invoice statuses are: • Approved = The invoice was approved, either automatically or by you, but has not yet posted to the originating system. • Held = The vendor has submitted the invoice, and the invoice includes at least one line that is because the vendor changed the unit price by more than the Unit Cost Threshold specified for the vendor: for example, you set a threshold of 10%, and the vendor changed the unit price by 15%. The invoice remains in Held status until the you either approve or reject it. • New = The vendor selected the Update and Save for Changes option when creating the invoice, and has not yet submitted the invoice to you for posting. • Posted = The invoice has been posted to the originating system, such as Oracle Retail Order Management System Cloud Service or CWDirect, for payment processing. • Rejected = The vendor submitted an invoice that includes an line, and you rejected it. The vendor can change the invoice so that it no longer contains an out-of-balance line, or can delete the invoice. Used by the Supplier Direct Fulfillment module. |
The nudge message that Order Broker sends to an integrated vendor indicating to request one or more new purchase orders through the getDSOrders message. See Vendor Integration for background, and see the Vendor Integration Guide for details. |
LDAP authentication in Order Broker enables a user to enter his or her standard network password to log in, rather than a separate password that is specific to Order Broker. See Domain Configuration for LDAP Authentication for more information. Not available for a vendor user. |
Routing Engine: See Order and Line Statuses for possible Order Broker statuses. Drop Ship: Possible purchase order line statuses are: • Cancelled: You have cancelled the line • Held: The vendor has held the line(s) on the purchase order from processing. When a line on a purchase order is on hold, it is not eligible for pack slip generation; or, if a pack slip has already been generated, the line is not eligible for shipment confirmation. • In Process: The vendor has generated a pack slip that includes the line. • New Order: The vendor has not yet generated a pack slip for the line. • Shipped: The vendor has confirmed shipment of the line. For more information: See order status. |
A request to the Routing Engine inquiring whether there are any locations that should be able to fulfill a delivery, retail pickup, or pickup order for one or more items, and the Routing Engine’s response message indicating the availability of the item(s). Order Broker receives the request and determines the availability information to include in the response by: • for product locations in online systems: sends an inventory inquiry • for product locations in offline systems: checks the current available quantity and purchase order information in the Order Broker database Order Broker sends the availability information to the requesting system in the locate items response. See The Routing Engine for an overview. |
A place where a product is sold or stocked. A location can be a warehouse or store where you keep actual inventory. It can also be a virtual location such as a web storefront or a vendor. Locations are defined within an organization both by the system to which they belong and their location type. You use the Locations screen to work with locations. Order Broker stores information on a location, including address, phone number, and hours of operation. These fields are informational only; however, the name and address information for the location that is displayed in the locate items response is derived from your entries at the Location screen. Created how? You must create each location within Order Broker in order to integrate its inventory for locate items searches. Sort order: The sort at the Preferences and Probability Location screens is in alphanumeric order within each organization. In other words, organizations are listed alphanumerically by name, as are location types within an organization, and locations within a location type. Since the sort is alphanumeric, numeric codes are listed before alphabetical codes; for example, location 123 is listed before location ABC. Location code requirements: The location code is alphanumeric, can be 1 to 10 positions long, and must be unique within an organization and system. For example, you can have two locations with a code of 10 in the same organization, as long as each is associated with a different system. For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including locations. |
Indicates whether each location type is a store (S) or a warehouse (W). Each location type must be assigned to one of these categories. Created how? The 2 location categories are delivered with Order Broker and cannot be changed. Order Broker does not evaluate locations differently based on their category; the category is informational only. |
Describes one or more locations within an organization. Each location type indicates the location category (store, warehouse, or vendor), and can also provide additional information, such as “East Coast Stores” or “Outlet Stores.” Created how? You must create each location type at the Location Types screen. Location type requirements: The location type code can be 1 to 10 positions long and must be unique within the organization. Display in drop-down boxes: The location type code and the location type name are displayed, separated by a hyphen (-). For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including location types. |
Indicates a basic product type. For example, the master style for a green shirt, size large, identifies the shirt itself; the color and size might represent styles in a POS system such as Xstore, and represent SKU’s in an order management and fulfillment system such as Order Management System. A master style can be defined at both the product and the system product levels. Master style requirements: The master style can be 1 to 35 positions in length. The master style is informational only. Normally, you would never change the master style for a product in Order Broker. Order Management System integration: The master style for Order Management System items is the base item number; the master style is populated only for SKU’d items and is set at both the product and system product levels, assuming that Order Management System is the default system. |
A message that Order Broker sends to an integrated vendor’s system to trigger the system to send Order Broker a message requesting new purchase orders. A nudge is generated through: • Selecting the generation of new purchase orders at the Get Purchase Orders screen in the Vendor Portal, or • Scheduling periodic nudges through the PO Schedule Interval set up under the Preferences tab of the New Vendor or Edit Vendor screen. The vendor can also set up the schedule in the Vendor Configuration screen in the Vendor Portal. |
The inventory information (Available Quantity, Next PO date, and Next PO Quantity) currently stored in Order Broker for a product location. Order Broker uses the offline inventory information in merchandise locator responses for product locations in: • an offline system: always • an online system: if Order Broker cannot receive an update from the system, and the No Offline Response Action setting at the Preference screen is set to Use offline. Used by the Routing Engine module. |
An offline system is one which Order Broker does not request real-time inventory updates when it receives a locate items request, product availability search request, or needs to select a fulfilling location for a delivery or retail pickup order, either as part of initial order creation or through the status update process; instead, it relies on the available quantity stored in the Order Broker database (offline inventory) to calculate the Available to Promise quantity. Typically, inventory levels in the Order Broker database are updated daily, or whenever scheduled by your systems administrator. Specified how? An offline system is identified by the Online flag being blank at the Systems screen. You clear this flag by clearing the Online checkbox at the System screen. Order Broker does not clear the connection information, if any, so that you can easily change an online system to an offline system and back again. |
An online system is one from which Order Broker obtains interactive inventory updates when it receives a locate items request, product availability search request, or needs to select a fulfilling location for a delivery or retail pickup order, either as part of initial order creation or through the status update process. Specified how? An online system is identified by the Online flag at the Systems screen. You set this flag by selecting the Online checkbox at the System screen. You must also provide connection information for Order Broker to use when requesting product and product location updates. Obtained how? Depending on the setting of the Connection Type field at the System screen, Order Broker either sends a RESTful service request to a URL or uses an interface program. See the System screen for more information. If no update available: When Order Broker cannot obtain an interactive inventory update, it uses the available quantity stored in the Order Broker database (offline inventory) to calculate the Available to Promise quantity, if the No Offline Response Action setting at the Preference screen is set to Use offline. The available quantity is updated either through a recent interactive inventory update, an incremental inventory update, or through the most recent product location import from the system. Typically, inventory levels in the Order Broker database are updated daily, or whenever scheduled by your systems administrator. See Import Process Overview for background. If Order Broker is not able to obtain an interactive inventory update, and uses the offline inventory information as a result, it considers the product location offline for the purposes of evaluating it for a probability rule. |
Routing Engine: The number identifying an Order Broker order in the originating system. From the order id passed in the submit order message. The Routing Engine uses both this order number and the request ID to track each order. The order number is alphanumeric and cannot exceed 30 positions. Supplier Direct Fulfillment: The number identifying the sales order that originated a drop ship purchase order assigned to a vendor for fulfillment. |
Routing Engine: See Order and Line Statuses. Drop Ship: Possible purchase order statuses are: • Cancelled: You have cancelled the purchase order. • Complete (multi-line purchase orders only): The purchase order includes more than one line, and the line statuses include a combination of Cancelled and Shipped; there are no remaining open lines. • Held: The vendor has held the line(s) on the purchase order from processing. When a line on a purchase order is on hold, it is not eligible for pack slip generation; or, if a pack slip has already been generated, the line is not eligible for shipment confirmation. • In Process: The vendor has generated pack slips for the purchase order. • New Order: The vendor has not yet generated pack slips for the purchase order. • Open (multi-line purchase orders only): The purchase order includes more than one line, and the line statuses include at least one line that is Held, In Process, or New Order. • Shipped: The vendor has confirmed shipment of the purchase order. For more information: See line status. |
The type of order, based on the transaction_type_id in the SubmitOrder message. Possible order types are: Used by the Routing Engine module. |
A request to the Routing Engine to reset the Under Review flag for an order. If this flag is selected, the fulfilling location should not complete fulfillment of the order. |
The highest level of the Order Broker data hierarchy, an organization includes the systems and products that can integrate with each other for the purposes of locate items searches, as well as the locations where products are sold or stocked. If there is more than one organization within Order Broker, searches do not cross from one organization to another. Created how? You must create the organization at the Organizations and Preferences screen as the first step in setting up data in Order Broker. Organization requirements: The organization code can be 1 to 10 positions long and must be unique within Order Broker. Display in drop-down boxes: The organization code and the organization name are displayed, separated by a hyphen (-). Display on screens: The organization code and the organization name are displayed, separated by a space. Default: On screens where the organization is available for searching or creating new records, this field defaults from the organization associated with the Default Shipping System from your user profile, but you can override this default. Note: You must complete the Preferences screen for an organization before you can select it. For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including organizations. |
The location (store or warehouse) that requested that an order be shipped, transferred, or prepared for pickup through the Routing Engine. Note: An integrated system might use a different term for this location. For example, in Order Management System the location where a ship-to-store order originates is designated as the fulfilling location, because it transfers the merchandise to the location where a customer will pick it up. |
An invoice detail line is out-of-balance if the vendor changes the unit price from the original purchase order unit price by more than the Unit Cost Threshold you specify for the vendor: for example, you set a threshold of 10%, and the vendor changes the unit price by 15%. Any change to unit price, either higher or lower than the original unit price, triggers out-of-balance evaluation. When the vendor submits the invoice, it does not post automatically to the originating system; instead, it remains in Held status until you either approve or reject it. The out-of-balance icon ( Used by the Supplier Direct Fulfillment module. |
pack slip |
The packing document that the vendor generates for drop ship purchase orders. Depending on the vendor’s preference settings, the pack slip can be in PDF format, CSV format, both, or neither. Used by the Supplier Direct Fulfillment module. |
An order line status update that specifies a unit quantity lower than the total quantity currently on the order line. For example, if the customer ordered 5 units and now wants only 4 units, the system might send a status update canceling 1 unit. Supported only if the Allow Partial Updates preference is selected for the organization. See Updating Order Status at the Line or Unit Level for an overview. Used by the Routing Engine module. |
An order to be picked up by the customer at a specified location, without requiring the Routing Engine to facilitate transferring the inventory to that location. See Pickup Order for more information. |
polled order |
An order or order line for which the assigned fulfilling location has been notified. Order lines flagged as polled are no longer be included in the fulfillments response message. The Routing Engine flags an order line as polled automatically if the fulfilling location’s system’s Require Status Update flag is unselected. Otherwise, if the Require Status Update flag is selected, the assigned fulfilling location must send a status update of either polled (any order type) or accepted (pickup, retail pickup, or delivery orders only). Note: Flagging an order or line as polled does not necessarily change the order or line status to polled. For example, the Routing Engine does not apply this status to a ship-to-store order if its current status is picked or intransit; and for other order types, setting the status to accepted also serves to flag the order or line as polled. See Require Status Update for Assigned Orders? for a discussion. Used by the Routing Engine module. |
You can set up rules that indicate any adjustments to make to the Available to Promise quantity, next PO date, or next PO quantity for a product location when you display this information in merchandise locator search results; or, you can set up a rule indicating not to include a product location in search results at all under certain conditions. Probability rules let you build additional intelligence into merchandise locator searches by accounting for predictable patterns in inventory activity. Setting up rules: See the Probability Rule Wizard for information on defining and assigning probability rules, including sample rules and an overview of rule hierarchy. Used by the Routing Engine module. |
A quantity, stored in the product_location table, based on the available to promise quantity after applying an assigned probable quantity rule, if any. The probable quantity is available for an external system, such as your system, to retrieve in order to provide more accurate availability information on the web storefront, but this quantity is not returned in any messages to integrated systems or displayed on any screens. See the Probable Qty Export tab of the System screen for background. |
A single inventory item that you sell in systems integrated with Order Broker. For example, you sell a pen as AB100 in Order Management System company 1. You sell the same pen as 345789123 in Xstore. Because your Order Management System company is your default system, the product is identified as AB100, and each of the related items in Xstore and other integrated systems is a system product, but all are related to the main product. Created how? Products are created in Order Broker when you use the product import process, download items, or export products from your default system. You can also create new products at the Products screen. Whenever you create a product, Order Broker also creates a system product for the default system. Product code requirements: The product code can be 1 to 35 positions long, and must be unique within a organization. Display on screens: The product code and the product name are separated by a space. For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including products. Used by the Routing Engine module. |
The Product Availability search message is similar to the locate items search, except that the Product Availability search: • can include more than one transaction type (pickup, retail pickup, and delivery) in a single request, and each type can include its own search range distance • does not include product location details for retail pickup and delivery searches; instead, it indicates: • if the entire requested quantity can be satisfied; otherwise, • if a partial quantity of the requested items can be satisfied, the maximum available quantity of each item • for a pickup request, always returns each item location that could partially fulfill the requested quantities of all requested items For more information: See Using Product Availability Search. Used by the Routing Engine module. |
A record of a product within a location where it is stocked or sold. For example, an item warehouse record in Order Management System corresponds to a product location. Order Broker stores availability information for the product location, including the available quantity and the date and expected quantity of any open purchase orders. Note: A system product must first exist for the product and system owning the selected location before you can create a product location. For example, if product AB123 does not exist in Order Management System company 10, then you cannot create a product location for AB123 in company 10’s warehouse 1. Available quantity updated when? For an offline system, the available quantity is updated only when you run the product import process or perform an inventory download from the system. For an online system, Order Broker also updates the available quantity, next PO date, and PO quantity for the product location when it receives a response to an inventory inquiry. Typically, inventory levels in the Order Broker database are updated daily, or whenever scheduled by your systems administrator. Created how? Typically, you create product locations through integrations with external systems. For example, product locations might be created as part of the product import process. For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including product locations. Used by the Routing Engine module. |
An inbound message to create a new product, system product, and product locations without using the full import process. See the Operations Guide for more information. |
The table that stores either U.S. zip codes or Canadian postal codes and the longitudes and latitudes of each. This information is required in order to perform proximity locator searches in Order Broker. For more information: See Proximity Uploads for more information on creating or updating the data in the proximity location table. Used by the Routing Engine module. |
Provides the ability to search for a product location based on its distance from the customer’s location. For example, the customer wants a certain product and would like to know if it is available within 25 miles from his home. If proximity locator searching is enabled, Order Broker can find any product locations within this distance from the customer. How is proximity calculated? Proximity locator searches are based on the longitude and latitude at the center of each zip or postal code based on the density of population within the zip or postal code. The distances indicated in the search results are not exact driving distances. For example, if the customer’s location is zip code 01701 and the specified product is available at a store location in zip code 01760, the indicated distance of 4.49 indicates the difference in longitude and latitude from the population center of 01701 to 01760; it does not indicate the actual driving distance from the customer’s home. See Proximity Locator Searching for more information. Used by the Routing Engine module. |
A unique number assigned by the Routing Engine to identify an order. See The Routing Engine for an overview. |
A location specified in the locate items request message if the customer is interested in requesting availability information for that store location only. When the request message specifies a requested location, the Routing Engine: • ignores the distance specified in the request and does not exclude the requested location based on proximity • always returns the actual location in the response message, rather than the virtual location, regardless of the setting of the Group Shipment Locations flag on the Preferences screen, and regardless of whether the location would otherwise be excluded because you are using zone fulfillment or because the location is within the same system and the Disallow shopping within same system flag is selected for the system • always returns a response even if the Available to Promise quantity is less than the requested quantity |
The quantity on all order lines assigned to this product location that are in a status indicating the inventory is reserved and should not be assigned to new orders or listed in the LocateItems response message. See Calculating the Available to Promise Quantity for an overview. Used by the Routing Engine module. |
An order that the customer will pick up at the originating location, requiring that the merchandise be sourced from one or more different locations. You can use the Routing Engine to select one or more locations to transfer the inventory to the originating location, or select locations manually. See Retail Pickup Order for more information. |
retailer |
The system that submits drop ship purchase orders to vendors through the Supplier Direct Fulfillment module in Order Broker. |
A user who has access to Order Broker screens in order to work with either the Routing Engine, possibly including Store Connect; or the Supplier Direct Fulfillment module; or both. |
The Order Broker module to: • select the best location(s) to fulfill a delivery or retail pickup order, either automatically based on criteria that you set for the enterprise, or by providing a list of possible locations • help the customer select a location for a pickup or ship-to-store order • determine whether inventory is available in the enterprise to fulfill a delivery or retail pickup order • create orders across the enterprise • notify locations about orders assigned to each location for shipment, transfer, or pickup • track order status • provide information on current order status upon request See The Routing Engine for an overview. |
sales velocity |
A numeric ranking you can use to indicate how well a product sells in a particular location. You can use the sales velocity ranks assigned to product locations as part of the Order Broker criteria for selecting fulfilling locations for orders. Numeric, 2 positions with an optional 2-position decimal. See the Order Broker Settings at the Preferences screen and the Order Broker Preference Overrides screen for more information. |
The message submitted by an integrated vendor to confirm receipt of a batch of purchase orders. If the Require Acknowledgement flag is selected for an integrated vendor, the acknowledgement is required to change the status of the purchase orders from New Order to In Process and generate the pack slip. See Vendor Integration for background, and see the Vendor Integration Guide for details. |
The request message sent from an external system, such as Oracle Retail Order Management System Cloud Service or CWDirect, to change the address on a drop ship purchase order. The request specifies whether to change just the shipping address, or both the shipping address and the sold-to address. Address changes are: • applied automatically if the purchase order or item is in New Order status • submitted to the vendor for review if the purchase order or line is in Held or In Process status • rejected automatically if the purchase order or line is in Shipped or Canceled status |
The request message sent from an external system, such as Oracle Retail Order Management System Cloud Service or CWDirect, to cancel a line on a purchase order. Cancellations are: • applied automatically if the line is in New Order status • submitted to the vendor for review if the line is in Held or In Process status • rejected automatically if the line is in Shipped or Canceled status |
The request message sent from an external system, such as Oracle Retail Order Management System Cloud Service or CWDirect, to change the cost on a purchase order. Cost changes are: • applied automatically if the line is in New Order status • rejected automatically if the line is in Shipped or Canceled status |
An order that the customer will pick up at a specified location, requiring that the Routing Engine facilitate transferring the merchandise to the selected location from the originating location. See Ship-to-Store Order for more information. Note: When the current status of a ship-to-store order is picked or intransit, the Routing Engine does not change the order’s status when it is polled by the assigned fulfilling location. |
If the Allow Split Order preference is selected, the Routing Engine assigns the lines on a delivery or retail pickup order to multiple fulfilling locations if it cannot find a single location that could fulfill the entire order. This setting also affects the locations returned in the locate items response message, and requires that status updates apply at the line level rather than the order level. See Selecting a Location for a Delivery or Retail Pickup Order for more information. |
splitting lines |
If the Allow Split Line preference is selected, the Routing Engine assigns a single order line to multiple fulfilling locations if it cannot find a single location to fulfill the entire line. This setting is available only if the Allow Split Order preference is also selected. See Selecting a Location for a Delivery or Retail Pickup Order for more information. |
status inquiry |
A message sent to the Routing Engine requesting the current status of an Order Broker order. See The Routing Engine for an overview. |
A message sent to the Routing Engine to update the status of an Order Broker order. See The Routing Engine for an overview. |
A separate user login for Store Connect, providing access to orders assigned to Store Connect locations. Authority for store associate users is controlled by a separate set of roles. See Store Associate User Profiles and the Role Wizard for more information. |
The Order Broker module that provides a suite of screens that a store associate can use to work with orders, assigned to the store location through the Routing Engine. You can assign store associate users to any locations associated with the system flagged as the Store Connect Default, and the associates can use the Store Connect screens to work with orders assigned to these locations. |
A message sent to the Routing Engine requesting creation of an order. See The Routing Engine for an overview. |
The Order Broker module that enables the retailer and the vendor to communicate about fulfilling drop ship purchase orders. |
An external database or business entity which integrates with Order Broker. For example, a system is an Xstore database or an Order Management System or CWDirect company. Created how? You must create each system at the Systems screen. System code requirements: The system code can be 1 to 10 positions long, and must be unique within Order Broker. Display in drop-down boxes: The system code and the system name are displayed, separated by a hyphen (-). For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including systems. |
An identification of a product within a particular system that is integrated with Order Broker. Created how? A system product is created for a product when you download items or import products from an external system, such as Order Management System or Xstore. You can work with system products at the System Products screen. System product code requirements: The system product code can be from 1 to 35 positions long. System products need to be unique within a system, but the same system product code can be assigned across multiple systems. For example, you cannot have more than one system product for AB123 in system 2, but you can have system product AB123 in systems 2, 3, and 4. For more information: See Data Hierarchy for an overview of the relationships among Order Broker elements, including systems. Used by the Routing Engine module. |
tenant |
Use the Tenant screen to review or work with attributes of your business in Order Broker at a level higher than the organization, such as specifying which modules to use. The Tenant - Cloud screen, available if you are an admin (cloud) user, includes additional settings required for cloud administration. Tenant-level settings apply to all your organizations in Order Broker. |
type |
See location type. |
The external organization that fulfills drop ship purchase orders for the retailer. Each purchase order processed through the Supplier Direct Fulfillment module is associated with a vendor. |
vendor default system |
A vendor default system is required before you can create any vendors to fulfill drop ship orders. An organization can have only one vendor default system. It is not necessary to specify any additional information for the vendor default system besides the organization, name, and this flag. |
vendor item |
The vendor’s item code. The CreateDSOrder message specifies the vendor item code for each item on a purchase order, and Order Broker creates the vendor item record automatically if it does not already exist. Used for the Supplier Direct Fulfillment module. |
The external website that a vendor can use to review, print, report shipments on, and create invoices for drop ship purchase orders through the Supplier Direct Fulfillment module. Each vendor user has access to screens in the vendor portal listing information related only to that purchase orders for the associated vendor. |
vendor preferences |
Preference settings specific to a vendor, including: • pack slip generation output, such as whether to generate pack slips in PDF or CSV format, and whether the pack slip PDF should be graphical or nongraphical • email addresses to receive notifications on purchase order activity A vendor user can also modify these settings with the required authority. See the Preferences tab at the New Vendor or Edit Vendor screen for more information. |
A separate user login to the vendor portal, providing access to the purchase orders for the associated vendor. Authority for vendor users is controlled by a separate set of roles. See the Role Wizard for more information. |
The location that the Routing Engine uses in the locate items response message to indicate that it can fulfill an order. The Routing Engine returns the virtual location in the response message only if you use the Group Shipment Locations option, indicating that requesting systems do not need to know which locations would be able to ship an order for the requested item(s), only that the order can be shipped (delivery order) or transferred (retail pickup order). The locate items response message lists the virtual location, rather than details on actual locations, if: • the Group Shipment Locations flag at the Preferences screen is selected • the Routing Engine receives a LocateItems request message with the fulfillment_type set to DELIVERY or RETAILPICKUP • the Routing Engine has found at least one location that should be able to fulfill each line on an order for the requested item(s) in the specified quantity(ies), or that is flagged as Backorder Available You do not need to create the virtual location in Order Broker. |
web service |
A programming component made available by a web server to perform specific programming tasks. For example, there is a discovery web service to supply an external system with the systems and locations set up in Order Broker for an organization. |
An option to restrict location selection for retail pickup or delivery orders based on the shipping address for an order, or based on the requesting location in a locate items request. You can set up zones to include addresses based on country, state or province, or zip code prefix range. Also, you can specify one or more primary store or warehouse locations to fulfill orders within the zone, as well as one or more alternate locations to use if the merchandise is not available within the primary locations. For more information: See Using Zones for Fulfillment. Used by the Routing Engine module. |
________________________________
Copyright © 2017, Oracle and/or its affiliates. All rights reserved.
Legal
Notices
