Purpose: Use the Order screen to view the details and activity of an order, or update the order’s status, or fulfilling or sourcing location, if you do not split orders (If you do split orders, you can use the Edit Order Item window to update an item’s status, or fulfilling or sourcing location). This screen is accessible to users with Order Inquiry authority; however, all fields are display-only if the user does not have Order Maintenance authority. See the Role Wizard for more information.
Used for the Routing Engine module.
Customer data anonymized? If the customer data on an order has been anonymized (deleted and replaced with asterisks), the sold-to and ship-to customer name, address, phone numbers, and email address are displayed as:
See Anonymizing Data for background.
How to display this screen: Click the edit/display icon () at the Order Inquiry screen. Available if Use Routing Engine is selected at the Tenant - Admin screen.
Note: If the Order screen was already open in another tab when you clicked the edit/display icon, you advance to this screen with the previously-selected order displayed.
In this topic:
• view order totals, addresses, and summary information
• view the activity that has taken place for each item on the order
• view the existing system products for an item on the order
• update the status of an order
• update the fulfilling location for a delivery or retail pickup order
Option |
Procedure |
Viewing Options |
Click the Header tab. This tab is selected by default. |
Click the Details tab. |
view the activity that has taken place for each item on the order |
Click the History tab. |
Click the system products icon ( Line split? If the line is split, this icon is available only after you click the plus sign for the requesting system line number to display additional fields and options: ![]() See the Details tab for a discussion. |
view additional information about an item, including the description, price and tax, and polled count, in a single window |
Click the edit/display icon ( Line split? If the line is split, this icon is available only after you click the plus sign for the requesting system line number to display additional fields and options: ![]() See the Details tab for a discussion. |
view the updated ship to address associated with the item |
Click the display icon ( See the History tab for a discussion. |
Maintaining an order Authority to maintain an order: You can update an order as described below if you have Order Maintenance authority. See the Role Wizard for more information. Maintenance at the order level or at the line level? If the Allow Split Order preference for an organization is: • Unselected: an order’s status, and fulfilling location or sourced location, are set at the order level. • Selected: an order’s status, and fulfilling location or sourced location, are set at the line level. Important: When you have Order Maintenance authority and the Allow Split Order preference is selected, you use the Edit Order Item window, rather than the Order screen, to maintain an order line’s status, or fulfilling or sourcing location. Cannot change both status and fulfilling location, or sourced location: You cannot change both the status and any location for an order or an order line at the same time. To change more than one field, first apply one change and click Save, then return to the Order screen and apply the other change. Caution: Updating an order or line’s status, fulfilling location, or sourced location is a means to correct occasional issues that may occur, and not recommended for routine processing. Except for the restrictions noted below, the screen does not prohibit most status or location updates. Note: Before updating an order, you can use other screens in Order Broker or contact a potential fulfilling, sourced, or pickup location directly to ensure that the update does not produce subsequent issues, such as fulfilling an order twice, reopening a shipped or canceled order, sourcing an order twice, or not fulfilling an order at all. |
If you have authority to Order Maintenance and the Allow Split Order preference for the organization is unselected, you can update the status of an order: • Select the new status from the Order Status field. Note: You cannot change the status of an order to Complete or Open, since these are statuses that Order Broker applies to an order only when the individual lines have different statuses. • Click Save. Restrictions: • You cannot change the status of a ship-to-store order to polled or rejected. • When you select a status from the Order Status field for a retail pickup or delivery order, the corresponding fulfilling location field (Shipment or Sourced) becomes display-only. Similarly, when you select a status from the Order Status field for a ship-for-pickup order, the corresponding Sourced location field becomes display-only. In order to change both the order’s status and its fulfilling or sourced location, complete one update and then return to the Order screen to complete the other update. |
Updates: • When you change the order status to new_order, canceled, or fulfilled, the Polled Count for the order lines are reset to 0. • When you change the order status to rejected: • retail pickup or delivery order: The Routing Engine reassigns the order and changes the status to new_order if another eligible location exists and if the Search Retries limit hasn’t been reached; otherwise, the Routing Engine changes its status to unfulfillable. • pickup order: The Routing Engine changes its status to unfulfillable. • ship-for-pickup order: The Routing Engine reassigns the order to a different sourcing location, and changes the status to new_order if another eligible sourcing location exists and if the Search Retries limit hasn’t been reached. For a ship-for-pickup order, a rejected status update generally indicates that the inventory was not received from the sourced location, or that it was defective. A ship-to-store order cannot be rejected. • A status change can update the reserved quantity for the product location, depending on the system’s Include Reserved setting and any Reserved Statuses for the system. See the System page for more information. • Order Broker tracks the activity in status history. See the History tab. |
update the fulfilling location for a delivery or retail pickup order |
If you have authority to Order Maintenance and the Allow Split Order preference for the organization is unselected, you can update the fulfilling location for an order: • Select the new fulfilling location from the field labeled: • Shipment for a delivery order • Sourced for a retail pickup order • Click Save. Which locations are available for selection? The dropdown list includes each location that supports the type of order: • For a delivery order, the location must be flagged as Delivery Available. • For a retail pickup order, the location must be flagged as Retail Pickup Available. You cannot select: • Any location where the order was previously assigned, even if it no longer supports the type of order. • The IN PROCESS location. See the Acknowledge Order Before Brokering preference for background. Note: The window does not prevent you from selecting a location: • where the item(s) are not available. If you do so, and if the Include Reserved flag is selected at the System screen, Order Broker creates a new record of the product location(s). • that is not associated with the zone for the order’s shipping location if you use zone fulfillment. For more information: See below for Restrictions. |
update the sourcing location for a ship-for-pickup order |
If you have authority to Order Maintenance and the Allow Split Order preference for the organization is unselected, you can update the fulfilling location for an order: • Select the new sourcing location. • Click Save. Which locations are available for selection? The dropdown list includes each location that is flagged as Ship For Pickup Sourcing Available. You cannot select: • Any location where the order was previously assigned. • The IN PROCESS location. See the Acknowledge Order Before Brokering preference for background. Note: The window does not prevent you from selecting a location: • where the item(s) are not available. If you do so, and if the Include Reserved flag is selected at the System screen, Order Broker creates a new record of the product location(s). • that is not associated with the zone for the order’s shipping location if you use zone fulfillment. For more information: See Ship For Pickup Order for background. |
• You cannot change the fulfilling location for a pickup order or ship-to-store order. • You cannot change the pickup location for a ship-for-pickup order. • When you select a location from the fulfilling location field (Shipment or Sourced) for a retail pickup or delivery order, the Order Status field becomes display-only. In order to change both the order’s status and its fulfilling location, complete one update and then return to the Order screen to complete the other update. • When you select a status from the Order Status field for a ship-for-pickup order, the corresponding Sourced location field becomes display-only. In order to change both the order’s status and its sourced location, complete one update and then return to the Order screen to complete the other update. Updates: • If you select the default unfulfillable location, the status of the order changes to unfulfillable. • Order Broker tracks the location assignment history. See the History tab. • If the system is configured to track reserved quantity and the line is in an applicable status, Order Broker updates the reserved quantity for the product location or creates the product location if it does not already exist. Otherwise, Order Broker does not create or update a product location. |
change an order line’s status or fulfilling location, and view additional information about an item, including the description, price and tax, and polled count, in a single window |
Fields |
Description |
Request ID |
See Request ID. |
Order Number |
See Order Number. |
Order Type |
See Order Type. |
The customer number, if passed as the customer_no in the submit order message, identifying the customer in the originating system. |
The transaction date and time passed in the submit order message. Might not be the same as the date when the order was created. If no time was specified in the message, the time displayed here indicates midnight (for example, 12:00 AM). |
(Field labels vary depending on the type of order) |
Placed = The location that originated a delivery order, pickup order, or ship-for-pickup order. Placed / Pickup = The location where the customer placed and picks up a retail pickup order. Pickup = The location a customer selected to pick up a pickup order, ship-to-store order, or ship-for-pickup order. Shipment = The location shipping a delivery order. This location might have been specified by the placed (originating) location, or selected by the Routing Engine based on the rules set up at the Preferences screen. Sourced / Placed = The location where a customer placed a ship-to-store order, and which transfers the inventory to the fulfilling location. Sourced = The location that transfers the inventory for a retail pickup order to the fulfilling location, or that transfers the inventory for a ship-for-pickup order to the pickup location. This location might have been specified by the placed (originating) location, or selected by the Routing Engine based on the rules set up at the Preferences screen. Multiple locations? If the Allow Split Order preference is selected, a retail pickup or delivery order can be assigned to multiple locations for fulfillment, and a ship-for-pickup order can be assigned to multiple locations for sourcing. In this case, this field displays the word Multiple and information on each assigned location is displayed under the Details tab. See Selecting a Location for a Delivery or Retail Pickup Order or Selecting a Sourcing Location for a Ship-for-Pickup Order for an overview. Update? You can update the fulfilling location for a retail pickup or delivery order, or the sourcing location for a ship-for-pickup order, if the Order Maintenance flag in your user profile is selected and the Allow Split Order preference for an organization is unselected. See Options at this screen for more information. Note: An integrated system might use different terms for these locations. For example, Order Management System uses the term “fulfilling location” to designate the location that originates a ship-to-store order rather than the location where the customer picks it up. |
See Order and Line Statuses for possible statuses. Update? You can update the order status if the Order Maintenance flag in your user profile is selected and the Allow Split Order preference for an organization is unselected. See Options at this screen for more information. |
A selected setting indicates that the fulfilling system needs to delay shipping or fulfilling the order until the flag is cleared. Note: • It is the responsibility of the integrating systems to prevent fulfillment of an order that is under review. Order Broker does not prevent fulfillment based on this setting. • The items on orders that are under review are still included in the reserved quantity calculation. Updates: You can select this flag through the initial submit order message, and can also update this flag: • through the OrderUpdate message • at this screen, if you have Order Maintenance authority The History tab displays a record of each time you change the setting of this flag. |
Effect of the Under Review indicator in Store Connect: • The order is still available to work with at the View New Orders screen, View All Open Orders screen, View Orders Ready for Picking screen, and Order To Be Picked screen • The order is included in the order totals at the home screen • The associate can generate the packing slip and the pick list pull sheet for the order • The order is not eligible for shipping or pickup • When the associate picks a pickup order, no email notification is sent to the customer until the setting of the Under Review indicator changes • If it is a pickup order, the associate cannot resend an email notification to the customer • If it is a delivery order, the Pick and Ship option is not available at the Pick Order window How the associate can tell if an order is under review: • The Under Review indicator is displayed at the at the View Order Detail screen, Pick Order Detail screen, Pick Order Detail - Item screen, and Scan Items to Pick screen: ![]() • An error window opens if the associate attempts to ship or pick up the order • The order is not displayed at the View Orders Ready for Shipping screen or the View Pickup Ready Orders screen |
If there are multiple request IDs with the same order number and ship via, and the Under Review indicator is not the same for all request IDs: Because Store Connect presents multiple request IDs as the same order if the request IDs have the same order number and ship via: • If all the items on the request IDs are in the same status, then the Under Review indicator prevents any of the items from shipping or being picked up. • If the item(s) on the request IDs are not in the same status, then it is possible for the item(s) on the request ID(s) that are not under review to be fulfilled (for example, a request ID that is not under review can be shipped, even though there is also a request ID that is under review, but its status is polled or accepted). |
Sold To |
Any of the following information on the customer placing the order, if it is passed in the submit order message: • first name, middle initial, last name • company name • first through fourth address lines, including any apartment or suite • city, state, Postal Code, and country • first phone number (prefixed by Day:) • second phone number (prefixed by Eve:) • email address Customer anonymized? If the customer data on an order has been anonymized, asterisks are displayed for the sold-to information. See Anonymizing Data for background. |
Any of the following information on the customer to receive a delivery order, or the address and contact information for the store where a customer picks up a retail pickup order, ship-to-store order, or ship-for-pickup order. • first name, middle initial, last name • company name • attention line (can be used for the name of the person to alert at the shipping destination) • first through fourth address lines, including any apartment or suite • city, state, Postal Code, and country • first phone number (prefixed by Day:) • second phone number (prefixed by Eve:) • email address Note: Order Broker does not support a ship-to address for a pickup order. Customer anonymized? If the customer data on an order has been anonymized, asterisks are displayed for the ship-to information. See Anonymizing Data for background. |
Summary |
Currency |
The description or ISO 4217 alphabetical code of the currency on the order. From the currency specified in the submit order message. If the currency is a valid alphabetical ISO 4217 code, the related currency symbol can be displayed for all order values. The default is the U.S. dollar (USD). Note: • The currency code must be all capitals to match the ISO 4217 code. • Not all currency symbols can be displayed on the screen. |
Sub Total |
The subtotal of merchandise on the order, and preceded by the symbol of the currency on the order. The screen displays a 2-position decimal, although the database stores 4 positions. If no amount was passed from the originating system, the amount indicated is 0. |
Any special instructions for handling the order. Integrated systems might use this field to store other information about the order. The instructions can be up to 4000 positions. |
Total |
The total amount of merchandise, tax, freight, and other charges on the order, preceded by the symbol of the currency on the order. The screen displays a 2-position decimal, although the database stores 4 positions. If no amount was passed from the originating system, the amount indicated is 0. |
The total amount of tax on the order, preceded by the symbol of the currency on the order. The screen displays a 2-position decimal, although the database stores 4 positions. If no amount was passed from the originating system, the tax indicated is 0. |
The ship via code and ship via description designated for the order from the ship_via and ship_via_description. Formatted as 12 - UPS Ground where: • 12 is the ship via • UPS Ground is the ship via description Different from carrier description? The description displayed here is from the SubmitOrder message and saved in the xom_order table, but this description does not update the carrier description displayed at the Carriers screen. The description from the Carrier record is used elsewhere in the application, including Store Connect screens, Store Connect printed output, and the shipment notification email generated for orders shipped through Store Connect. If no ship via specified in the SubmitOrder message: • For a retail pickup, delivery, or ship-for-pickup order, the Default Carrier specified at the Preferences screen is used. • The default PICKUP carrier is used for a pickup order. If the default PICKUP carrier does not exist, Order Broker creates it. • The default SHIP2STORE carrier is used for a ship-to-store order assigned to a Store Connect location. If the default SHIP2STORE carrier does not exist, Order Broker creates it. Ship-to-store orders in Store Connect: The ship via is changed to the default SHIP2STORE carrier for ship-to-store orders assigned to Store Connect locations for fulfillment. |
Balance Due |
The total balance due on the order, preceded by the symbol of the currency on the order. The screen displays a 2-position decimal, although the database stores 4 positions. If no amount was passed from the originating system, the amount indicated is 0. |
Freight |
The total amount of freight on the order, preceded by the symbol of the currency on the order. The screen displays a 2-position decimal, although the database stores 4 positions. If no amount was passed from the originating system, the freight indicated is 0. |
Gift |
Set to Y or N, if passed in the submit order message; otherwise, blank. |
Is line split? Provided the Allow Split Order preference is selected, a line can split if: • the Allow Split Line preference is selected, and the Routing Engine split a line when initially creating a retail pickup or delivery order, or after the line was rejected by an assigned location; or, • the Allow Partial Updates preference is selected, and the Routing Engine received a status update for a quantity lower than the current line quantity. Even if your preferences support splitting lines or partial status update, this does not necessarily mean that the lines on an order will split. Split lines at Details tab: If any line on the order is split, you need to expand the requesting system line number at the Details tab in order to see and work with the details for all lines and see additional options: ![]() Non-split lines at Details tab: If none of the lines on the order are not split, the details and options are displayed when you open the Details tab: ![]() For more information: See Selecting a Location for a Delivery or Retail Pickup Order for some of the different scenarios that are possible in creating or updating detail lines on retail pickup or delivery orders if you have Order Broker configured to split orders or order lines. Also, see Updating Order Status at the Line or Unit Level for an overview on processing partial status updates for order lines. |
The line number identifying the order line in the requesting location. From the line_item_no passed in the submit order message. A single line from the requesting system can create multiple order lines in Order Broker if the Allow Split Line preference is selected. Also, a line can split as the result of a partial status update if the Allow Partial Updates preference is selected. Even if a line is not split in Order Broker, the requesting system line number can be different from the line number in Order Broker. For example, this situation can occur if the placed (originating) location sends only the third line on a multi-line order to Order Broker; in this case, the line number in Order Broker is #1. If split: If any lines on the order are split, you need to expand the line to see additional details and options. Click the plus sign next to the requesting system line number to expand: ![]() |
The order line number assigned by Order Broker. May be different from the requesting system’s line number if the system did not send all of the order lines to Order Broker for fulfillment and the version specified in the submit order message was lower than 3.0, or if an order line is split. If split: If any of the lines on the order are split, the Item # is before the Order Broker Line # and is always displayed, even if you have not expanded the line by clicking the plus sign next to the Req. Sys. Line # (Requesting system line number); however, the Line # and other fields are not displayed until you click the plus sign. Examples of line splitting: • Split by the Routing Engine: • The Routing Engine assigns the order to location A, and then Location A rejects the order • The Routing Engine then assigns half the quantity to location B, and half to location C. Result: the quantity in location B is now line #1; the quantity in location C is now line #2 • Partial status update: The entire quantity of 5 was originally assigned to location A, but location A rejected 3 units. Result: the quantity in location A is now line #1; the rejected quantity, now reassigned or unfulfillable, is now line #2 |
Different line numbers even if not split: It is possible for the Order Broker line number and requesting system line number to differ if, for example, the requesting system sends line 3 of a multi-line order to Order Broker (requesting system line number); when the Routing Engine creates the order, it assigns a line number of 1 because it is the only order line received from the requesting system. Line numbers might not be consecutive: If the Routing Engine splits a line or receives a partial status update, the line numbers assigned in Order Broker to the resulting split lines might not be consecutive. For example, a system sends 3 lines, which produce lines 1, 2, and 3. Subsequently, the Routing Engine receives a partial update for line 1 and creates line 4 for the quantity in the updated status. If not split: If none of the lines on the order are split, just a single line number is displayed. |
The system product code for the user’s Default Shipping System. If the user’s Default Shipping System is not in the organization associated with the order, the system product code for the fulfilling location is displayed. Up to 26 positions. If split: If any of the lines on the order are split, the Item # is before the Order Broker Line # and is always displayed, even if you have not expanded the line by clicking the plus sign next to the Req. Sys. Line # (Requesting system line number). No item #? If your user ID is not assigned a Default Shipping System at the User Profile Configuration screen, the Item # might not be displayed here. Note: You can display the item description by moving your cursor over the item code. |
Quantity |
Original quantity: If the line is split, the quantity displayed on the first line without a current line number is the quantity of the item that was originally assigned to the Fulfilling Location or Sourced Location. This quantity might differ from the quantity originally submitted to Order Broker if the Allow Split Line preference is selected, and the Routing Engine initially split the line across multiple fulfilling or sourcing locations. Also, the original quantity in Order Broker might subsequently be split across multiple order lines in Order Broker if the original fulfilling or sourcing location rejects the assignment and the Routing Engine splits the line when it reassigns it, or if a location submits a partial status update. Current quantity: The quantity that is currently assigned to the fulfilling, sourcing, or pickup location. This quantity might be different from the original quantity if the Allow Split Line preference is selected, and the Routing Engine split the line across multiple fulfilling or sourcing locations after it was initially rejected by the first location, or if a location submits a partial status update. Not split: If the line is not split, the original and current quantities are the same. If none of the lines on the order are split, then just a single quantity is displayed. |
Fulfilled Quantity |
The quantity of the item shipped to the customer (delivery order) or picked up by the customer pickup order, retail pickup order, ship-to-store order, or ship-for-pickup order). Updated when the Routing Engine receives a status update message indicating that the new order, line, or quantity status is fulfilled. If split: The total fulfilled quantity is displayed at the summary level for the line, and the fulfilled quantity for each current line number is listed below with the current line. |
The fulfilling location that was most currently assigned to fulfill the item. Displayed only if the order is not a ship-for-pickup order. If split: If the line is currently split across multiple fulfilling locations, the word Multiple is displayed at the summary level. You can expand the line to review all assigned locations by clicking the plus sign to the left. Update? You can update the fulfilling location for a line if the Order Maintenance flag in your user profile is selected and the Allow Split Order preference is selected. See Edit Order Item for more information. |
The sourcing location that was most currently assigned to source the item for a ship-for-pickup order order. If split: If the line is currently split across multiple sourcing locations, the word Multiple is displayed at the summary level. You can expand the line to review all assigned locations by clicking the plus sign to the left. Update? You can update the sourcing location for a line if the Order Maintenance flag in your user profile is selected and the Allow Split Order preference is selected. See Edit Order Item for more information. |
Pickup Location |
The pickup location for a ship-for-pickup order order. |
Update? You can update the line status if the Order Maintenance flag in your user profile is selected and the Allow Split Order preference for an organization is selected. If the Allow Partial Updates preference is selected, you can also specify a partial quantity to update with the new status. See Edit Order Item for more information. |
Status Date |
The last date and time when the status of the order changed. When a ship-to-store order in picked or intransit status is flagged as polled, the Routing Engine does not change the current status of the order, so the Status Date does not change. |
System Products |
Click the system products icon ( |
Display/Edit |
Click the display/edit icon ( |
This tab displays the status history for each line on the order, created whenever a line is: • created, or • assigned or reassigned to a fulfilling or sourcing location, or • when its status changes for any other reason, or • when its shipping address is updated, or • when there is an update to the Under Review indicator • when a store associate closes an item on a ship-to-store order (the status changes to canceled) • when the customer data is anonymized through the Purge Customer Data from Completed Orders or through the ForgetPrivateData web service request The History tab lists records for each item in reverse chronological order (newest to oldest). A single transaction can create multiple history records if the transaction splits the line due to a partial status update or reassignment of a rejected order to multiple fulfilling locations. Optionally, you can collapse the history for an item by clicking the box next to the line number. ![]() Note: Status history and changes to the Under Review indicator are tracked at the line level even if the organization does not split orders or order lines. |
Item # |
The system product code and item description for the user’s Default Shipping System. If the user’s Default Shipping System is not in the organization associated with the order, the system product code and item description for the fulfilling or sourcing location is displayed. Up to 26 positions. |
The current line number at the time the activity took place. This number might differ from the current line number if the Routing Engine split the line after initial creation in Order Broker because the original fulfilling location rejected it. Which line number? The status history entry always lists the line number referenced in the status update request, even if the status update creates a new line number. Example: Line 10 currently includes 5 units in picked status. A partial status update indicates to change the status of 3 units on the line to fulfilled status. This update changes the quantity of line 10 to 2, and creates a new line, line 11, for 3 units in fulfilled status. However, both status history entries list line number 10, since that was the line number referenced in the status update request. The Routing Engine does not write a separate status history record for the creation of line 11. Under Review update: An update to the Under Review indicator creates a history record for each line on the order. For more information: See the Line # for an example of how the Routing Engine might track the same order line using different line numbers. |
Requesting System Line Number |
The line number identifying the order line in the requesting location. From the line_item_no passed in the submit order message. A single line from the requesting system can create multiple order lines in Order Broker if the Allow Split Line preference is selected. |
Quantity |
The order line quantity at the time the activity took place. Might differ from the current quantity if the line was rejected by the original fulfilling or sourcing location and split by the Routing Engine at reassignment, or if the transaction was a partial status update. |
The status as a result of the activity indicated. See Order and Line Statuses. Note: When an order is rejected and it cannot be reassigned and, as a result, the Routing Engine changes its status to unfulfillable, 2 history records are written: 1 for the rejected status, and 1 for the unfulfillable status. Under Review update: An update to the Under Review indicator creates a history record using the order-level status, even if the status of an individual line is different; however, this update does not affect the actual status of individual lines. Example: An order includes a line in polled status and a line in new order status, so the status of the order is open. You update the Under Review indicator for the order. The history record indicates a status of open on both lines, although the status of the polled and new order lines does not change. |
Location |
The code and description of the location where the change occurred, or which requested the status change. Under Review update: An update to the Under Review indicator creates a history record using the current fulfilling location for the order, regardless of the location that submitted the update. Locations for ship-for-pickup order: The location listed when a ship-for-pickup order is intransit is the sourcing location, while the location listed when a ship-for-pickup order is fulfilled is the pickup location. See Ship For Pickup Order for background. |
Date/Time |
The date and the time when the activity occurred, such as the status changed, or when a ship-to-store order was flagged as polled; see Require Status Update for Assigned Orders? for a discussion. |
User |
Indicates the user who performed the activity, such as creating the order or updating the status of the order or line: • creation: the employee_id from the submit order message • change: depending on how the change was made: • status update message or OrderUpdate message: the employee_id • order maintenance: the user ID of the person who updated the order • changing a Store Connect order to polled based on the settings from the New Order Polling Schedule tab (Schedule): Admin • Store Connect activity: the store associate user ID; however: • if this is a rejection, and the store associate required approval from another store associate user with Reject Approval authority, this is the user ID of the user who approved the rejection. • if this is an address change, and the store associate required approval from another store associate user with Edit Ship To Address authority, this is the user ID of the user who approved the edit. • putting the line in polled status through a fulfillments message, or in intransit polled status through an intransit message: SYSTEM. The status change takes place only if the system’s Require Status Update flag is not selected. • anonymizing the customer data through the Purge Customer Data from Completed Orders window or through the ForgetPrivateData web service request: SYSTEM. Note: • The employee ID specified in an inbound message might not be a valid user ID in Order Broker. • The user ID is truncated if it exceeds 10 positions. |
Source |
Indicates how the order was created or updated: • WS: • an XML message (such as the submit order message, status update message, or OrderUpdate message, or polling of an order through the fulfillments message or the intransit message), or • any Store Connect activity, including changing an order to polled based on the settings from the New Order Polling Schedule tab (Schedule) or activity by a store associate user through a Store Connect screen, or • anonymizing the customer data through the Purge Customer Data from Completed Orders window or through the ForgetPrivateData web service request • UI: a user made the change at the Order screen |
Transaction Notes |
Possible transaction notes from the xom_status_history table: • Carrier: The carrier (shipping agent), if any, passed in the status update message from the assigned fulfilling location, or specified through Store Connect. • Tracking #: The tracking number, if any, passed in the status update message from the assigned fulfilling location, or specified through Store Connect. • Carton #: The carton number, if any, passed in the status update message from the placed (originating) location when it changes the order or line status of a ship-to-store or retail pickup order to Intransit. • Reason Code: The status reason code, if any, passed in the status update message. • Reason description: The description of the cancellation reason selected when an associate canceled the line in Store Connect. • Note: The status reason note, if any, passed in the status update message. • Under Review: The current setting of the Under Review indicator, indicating: • Yes = the fulfilling system needs to delay shipping or fulfilling the order until the flag is cleared • No = the order is eligible for fulfillment • Reject - reason description: The description of the reject reason selected when an associate rejected the line in Store Connect. • Address Change Applied: Click the details icon ( • Private Data Anonymized: The order has been anonymized, either through Purge Customer Data from Completed Orders, or through the ForgetPrivateData web service request. |
Science Engine responses: If you use weighted brokering, responses from the Science Engine can produce the following Transaction Notes: • Exceed Maximum Number of Splits: The Science Engine returned a code indicating that the entire order could not be fulfilled without exceeding the Maximum Order Splits, so the entire order is unfulfillable. This response can occur for a single-line order that could have been fulfilled by splitting the line, but split line is not enabled. A reason code of 1000 is stored as the UNFULFILLABLE_REASON_CODE in the XOM_STATUS_HISTORY table. • Not Enough Inventory and No Backorder Location: The Science Engine returned a code indicating that the entire order, or a line on the order, could not be fulfilled because there was not sufficient inventory on-hand, and there was not an eligible location that supported backorders. A reason code of 2000 is stored as the UNFULFILLABLE_REASON_CODE in the XOM_STATUS_HISTORY table if the entire order was unfulfillable, and a reason code of 3000 is stored for an individual line that was unfulfillable while other line(s) could be fulfilled. • Not Fulfilled due to Split Not Allowed: The Science Engine returned a code indicating that the entire order could not be fulfilled without splitting one or more order lines, and Allow Split Line was not selected. The same message is displayed if the order could not be fulfilled without splitting the order, and Allow Split Order was not selected. A reason code of 7000 is stored as the UNFULFILLABLE_REASON_CODE in the XOM_STATUS_HISTORY table if the entire order was unfulfillable, and a reason code of 6000 is stored for an individual line that was unfulfillable while other line(s) could be fulfilled. |
Additional Science Engine reason codes: The following reason codes are stored in the UNFULFILLABLE_REASON_CODE in the XOM_STATUS_HISTORY table, but no Transaction Notes are displayed, based on responses from the Science Engine: • 4000: An order or line had to be assigned to a backorder location that was currently without sufficient inventory, because the entire order could not be assigned to locations with sufficient inventory without exceeding the Maximum Order Splits. For example, an order includes a line for 1 unit of item A, and another line for 2 units of item B. Location 100 can fulfill the line for item A. Locations 200 and 300 each have 1 unit item B. The Maximum Order Splits is set to 2. If location 200 supports backorders, the line with 2 units of item B is assigned there. • 5000: An order or line had to be assigned to a backorder location that was currently without sufficient inventory, because there were no locations that had the inventory on-hand; however, this was not the result of the Maximum Order Splits setting being exceeded. • 8000: An order or line could have been assigned to locations with inventory if split order or line were allowed; but since the order or line could not be split, it was assigned to a backorder location that was currently without sufficient inventory. |
About status reason codes and notes: The assigned fulfilling or sourcing location might pass a status code or note, or both, indicating why it rejects an order or line; or a location might pass a status code or note, or both, indicating why to cancel an order or line. About status reason codes and notes: The assigned fulfilling or sourcing location might pass a status code or note, or both, indicating why it rejects an order or line; or a location might pass a status code or note, or both, indicating why to cancel an order or line.About rejection and cancellation reason codes: Defined through the Reason Codes screen, and available for the store associate to use when rejecting or canceling an order or item if the code is flagged as Active. Transaction notes displayed when? 1. The carrier or tracking number, or both; position the cursor over this line to display the complete carrier and tracking number if the information is truncated on the screen; otherwise, 2. The reason note if there is no carrier or tracking number; position the cursor over the note to display the complete code and note, if the code is truncated on the screen; otherwise, 3. The reason code if there is no carrier, tracking number, or note; position the cursor over the code to display the complete code if it is truncated on the screen. Transaction notes from Store Connect: Position the cursor over the reason description to display: • for a rejection: • Reason Code: code • Note: Reject - description Where code is the reason code itself, and description is the reason description • for a cancellation: • Reason Code: code • Note: reason description Where code is the reason code itself, and description is the reason description |
Details |
If the ship to address changed, click the details icon ( |
________________________________
Copyright © 2018, Oracle and/or its affiliates. All rights reserved.
Legal
Notices
