\RCU\BIN\ from the installation archive, and then double-click the rcu batch file to start the Oracle Repository Creation Utility (RCU).Figure 12-1 Oracle RCU Components Selection for Oracle Database
orclrna_biplatform and orclrna_mds users no longer exist.root\Oracle\databaseInstanceName\mymicros\ and verify that ORCLRNA_BIPLATFORM.DBF, ORCLRNA_MDS.DBF, and ORCLRNA_IASTEMP.DBF have been deleted.System.SCHEMA_VERSION_REGISTRY$ entry:
delete from System.SCHEMA_VERSION_REGISTRY$ where mrc_name='ORCLRNA';
obieeRcu records from the CORE_OPTIONS table:
delete from CORE_OPTIONS where modulename='obieeRcu';
Parent topic: Uninstallation
