The following configurable parameters will be made are available as part of the InsightConfigMbean. The mBean is as follows:
com.oracle.procmon.engine.management.mbeans.impl:name=InsightConfigBean,type=ConfigMBean,Application=insightParameters
The details of the parameters are described below:
BAMMetricsRetentionPeriod — this parameter controls the retention period of the metrics captured as part of BAM Data Objects . The default value is 90 days. Once the attribute is updated, the retention period of BAM Data Objects of all activated models gets updated with the same value. A value of 0 signifies that the metrics will be retained indefinitely and never be purged.
EventStoreRetentionPeriod — this parameter controls the retention period of the raw events captured. The default value is -1, which implies that table data will be purged immediately once they are processed and metrics published in BAM. A value of 0 implies that data will not be purged. A change in value of this attributes needs a server restart for the purge job to take effect.
