- Click the Administration tab or the navigational shortcut on the Home page.
The Data Connections page opens.
- Click the Edit icon (the pencil icon) next to the connection you want to edit.
The
Edit Connection dialog opens.
- Click Retest Connection to test the connection with the changes you have made.
The connection state changes to Configured if the test passes or Disconnected if the test fails.
- Make the required updates and click Save.
The data connection is edited with the changes you made.
