The Products and Ensembles tab allows you to manage the products and ensembles that are included in the current category. You can work with the products and ensembles using a table or a grid view.
View: Select a way to view the items.
Table: If viewing the items in a table, you will see the controls listed on the Table page.
Grid: If viewing the items in a grid, you will see the controls listed on the Grid page.
Add Product: This button is available in both the table and grid views. It allows you to add a product the current category. A pop-up window will appear which will allow you to search for and select the product to add.
Add Ensemble: This button is available in both the table and grid views. It allows you to add an ensemble to the current category. A pop-up window will appear which will allow you to search for and select the ensemble to add.
