Use this page to create new search indexes and swap them into use. Search indexes are built separately from the active index. To generate and use a new index, you need to build it and then swap it into place.
Select the "Build Index" checkbox.
Select "Go".
Select the "Switch Index" checkbox.
Select "Go". The new index will be swapped for the active one and will become the one that is used for searches.
