This manual is designed to help you get acquainted with the manner in which various classes can be set up in Oracle FLEXCUBE.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office clerk | Input functions for contracts | ||
| Back office managers/officers | Authorization functions | ||
| Product Managers | Product definition and authorization | ||
| End of day operators | Processing during end of day/ beginning of day | ||
| Financial Controller / Product Managers | Generation of reports |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
| Chapter | Description | ||
| Chapter 1 | About this Manual gives a brief introduction to the module. It also lists the various chapters in the User Manual. | ||
| Chapter 2 | Creating Classes details the procedure to set up different classes in Oracle FLEXCUBE. |
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
For further information on procedures discussed in the manual, refer to the Oracle FLEXCUBE manuals on:
