This manual is designed to help you to quickly get acquainted with the Limits and Collateral Management module. It provides an overview and takes you through the various steps involved in setting up and maintaining the Limits and Collateral Management module.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
This manual is intended for the following User/User Roles:
Role | Function | ||
Back office data entry clerk | Input functions for funds | ||
Back office managers/officers | Authorization functions | ||
Product Managers | Product definition and authorization | ||
End of day operators | Processing during end of day/ beginning of day |
This manual is organized into the following chapters:
Chapter | Description | ||
Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
Chapter 2 | Limits & Collaterals explains a series of maintenance options facilitated in Limits and Collateral Management module. | ||
Chapter 3 | Queries explains about the query functions and helps you to query records on Liabilities, Transactions, Collateral Covenants, and so on. | ||
Chapter 4 | Reports provide a list of reports that can be generated in this module and also explains their contents. | ||
Chapter 5 | Annexure 1 - Value Dated Facility describes how to track and maintain all facility utilizations based on the value date of the transaction. | ||
Chapter 6 | Annexure 2 – Revaluation describes how to maintain the fluctuating exchange rates of marketable securities such as currency and collateral, over a period of time. | ||
Chapter 7 | Annexure 3 - Gateway Processes & Interfaces details on how an external system can be integrated with LCM module for communication. | ||
Chapter 8 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
You may find the following acronyms/abbreviations in this manual.
Acronym | Description | ||
UI | User Interface | ||
LCM | Limits and Collateral Management | ||
FCUBS | Oracle FLEXCUBE Universal Banking Solution | ||
GW | Gateway | ||
HTTP | Hyper Text Transfer Protocol | ||
XML | eXtensible Mark-up Language | ||
XSD | XML Schema Definition | ||
XSLT | eXtensible Stylesheet Language Transformations | ||
BPEL | Business Process Execution Language | ||
SMS | Security Services | ||
ID | Identification Number | ||
PK | Primary Key | ||
RDBMS | Relational Data Base Management System | ||
VD | Value Date | ||
Mark EOTI | Mark End of Transaction Input | ||
Mark TI | Mark Transaction Input | ||
TD | Term Deposits | ||
CIF | Customer Information File |
This User Manual may refer to all or some of the following icons:
Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
