This manual is designed to help acquaint you with the integration of Oracle FLEXCUBE and Oracle FLEXCUBE Document Management System Interface.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office data entry Clerks | Input functions for maintenances | ||
| Back office Managers/Officers | Authorization functions |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
| Chapter | Description | ||
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Oracle FLEXCUBE - DMS Integration explains about Oracle IPM which is an external Document Management System with which Oracle FLEXCUBE integrates for document processes. |
| Abbreviation | Description | ||
| DMS | Document Management System | ||
| IPM | Imaging and Process Management |
This document talks about the required maintenance and further processing of data transfer between Oracle FLEXCUBE and DMS.
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
You can refer to the following documents:
