This manual is designed to help acquaint you with the integration of Oracle FLEXCUBE and Oracle FLEXCUBE General Ledger (FGL) system.
This manual provides you extensive explanations about the maintenances and processing of exchange of data between Oracle FLEXCUBE and FGL. Besides this User Manual, while maintaining the details, you can invoke the context sensitive help available for each field. This help encapsulates the purpose of each field within a screen. Placing the cursor on the relevant field and striking the <F1> key on the keyboard can obtain information specific to a particular field.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office data entry Clerks | Input functions for maintenances | ||
| Back office Managers/Officers | Authorization functions |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
| Chapter | Description | ||
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Oracle FLEXCUBE – FGL Integration explains about the integration of Oracle FLEXCUBE and Oracle FLEXCUBE General Ledger (FGL) system. | ||
| Chapter 3 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
| Abbreviation | Description | ||
| System | Unless and otherwise specified, it shall always refer to Oracle FLEXCUBE system | ||
| SDE | System Data Element | ||
| FGL | Oracle FLEXCUBE General Ledger | ||
| GL | General Ledger |
This document talks about the required maintenance and further processing of data transfer between Oracle FLEXCUBE and FGL. This includes the following:
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
You can refer to the following documents:
