This chapter contains the following section:
The following are the various accounting entries for RTGS and SKN Messages.
If the transaction does not fall in to any of the exception queues, then both ‘DRLQ’,’CRLQ’ will be processed.
| Event | Account | Debit/Credit | Amount | ||||
| DRLQ | Network GL | Credit | Charge Amount | ||||
| DRLQ | Intermediary GL | Debit | Charge Amount |
| CRLQ | Charge/Fees GL | Debit | Charge Amount | ||||
| CRLQ | Intermediary GL | Credit | Charge Amount |
| DRLQ | Incoming Network GL (NOSTRO) | Debit | Transaction Amount | ||||
| DRLQ | Intermediary GL | Credit | Transaction Amount |
| CRLQ | Intermediary GL | Debit | Transaction Amount | ||||
| CRLQ | Customer Account | Credit | Transaction Amount |
If the transaction falls on incoming authorization queue then ‘DRLQ’ event will be processed.
If the transaction is completely authorized from the incoming authorization queue that means the transaction not falls on any exception queue then system will process the ‘CRLQ’ event.
If the incoming payment is rejected from the incoming authorization queue then system will process ‘CRLQ event
| CRLQ | Unsettle GL(will be picked up from Product Category) | Credit | Transaction Amount |
If the incoming payment or return of outgoing payment is suspended from the incoming authorization queue then system will process the ‘CRLQ’ event with following accounting entries
If the incoming payment or return of outgoing payment is authorized from the repair queue then system will not post any accounting entries and the transaction will be moved into incoming authorization queue.
If the incoming payment is rejected from the repair queue then system will process ‘‘CRLQ event
If the contract is moved to release queue, then ‘DRLQ’ event will be processed.
| DRLQ | Customer Account | Debit | Transaction Amount | ||||
If the contract is released from Release queue, then CRLQ event will be processed.
| CRLQ | Outgoing Network GL (NOSTRO) | Credit | Transaction Amount |
If the contract does not require any manual authorization or release action then both ‘DRLQ’ and ‘CRLQ’ event will be processed. Accounting entries will be posted as below:
| DRLQ | Intermediary GL | Credit | Transaction Amount | ||||
If the contract is rejected from Release queue, then contract will be reversed and the accounting entries will be as given below:
| REVR | Customer Account | Debit | Negative transaction Amount | ||||
| REVR | Intermediary GL | Credit | Negative transaction Amount |
If the contract is rejected from Authorization (A1, A2) queues, then system will not process any accounting entries.
For Reject of Incoming Payments (IN) contracts following accounting entries will be posted for DRLQ and CRLQ events.
| DRLQ | Unsettle GL | Debit | Transaction Amount | ||||
