This manual is designed to help acquaint you with the interface between Oracle FLEXCUBE and the other systems within your bank.
This manual provides you extensive explanations about the various maintenances required for the smooth exchange of data between Oracle FLEXCUBE and the applicable systems through the interface. It also gives you an insight into the processes involved in the actual exchange of data.
This manual is intended for the following User/User Roles:
| Role | Function | ||
| Back office data entry Clerks | Input functions for maintenance related to the interface | ||
| End of day operators | Processing during end of day | ||
| Implementation Teams | For setting up integration | ||
| Product Managers | Product definition and authorization | ||
| Financial Controller / Product Managers | Generation of reports |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This chapter is organized into following chapters:
| Chapter | Description | ||
| Chapter 1 | Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual. | ||
| Chapter 2 | Oracle FCUBS - DAP Integration explains the integration between Oracle FLEXCUBE Universal Banking and Direct Accounting Process. |
| Abbreviation | Description | ||
| System | Unless and otherwise specified, it always refers to Oracle FLEXCUBE Universal Banking system | ||
| FCUBS | Oracle FLEXCUBE Universal Banking System | ||
| DAP | Direct Accounting Process | ||
| GL | General Ledger | ||
| ISB GL | Inter System Bridge General Ledger |
This user manual may refer to all or some of the following icons.
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
Along with this user manual you may also refer the following related resources:
