To apply interest or charges on an account, you require certain data. For example, to calculate interest for an account you would require the following data:
When you want to apply charges on an account, you may have to specify the conditions for which you would need to apply charges. The amount that is charged may be different for different conditions. For example, you may want to apply charges on every extra account statement that has to be given to the customer.
When you define a ‘Rule’, you specify exactly how such data is to be picked up for calculating either the interest or charge. A ‘Rule’ identifies the method in which interest or charges have to be calculated.
The data required to calculate interest and charges are broadly referred to as ‘data elements’. Data elements are of two types:
Using the System Data Elements and the User Data Elements that you define for a rule, you can create formulae. Formulae connect SDEs and UDEs to give a result. The result of a formula is the interest or charge that has to be applied on an account.
To use a metaphor, SDEs and UDEs are the pillars on which an arch called formula rests. Many arches combine to form a dome called Rule. The things that you choose to put under a dome correspond to account classes (or accounts themselves) to which the rule applies.
You can build arches (formulae) to complete the domes (rules) that you are creating in the ‘Formula Wizard’ screen.
Note
You can define any number of formulae for a rule.
Element
To build a formula you require certain building blocks. These blocks could be SDEs, UDEs or (the result of) other formulae that you have previously created.
Operators
Operators are symbols that you would use to build mathematical expressions while defining a formula. The following is a list of symbols that you would require to build a formula.
| Operator | Description | ||
| + | Plus | ||
| - | Minus | ||
| / | Divide by | ||
| * | Multiply |
Logical Operators
Logical Operators are indicators of certain conditions that you specify while building a formula. The following is a list of logical operators that you would require to build a formula: ‘AND’ ‘OR’ and:
| AND | the conjunction ‘and’ | ||
| OR | the conjunction ‘or’ | ||
| > | greater than | ||
| >= | greater than or equal to (please note that there is no space between the two symbols) | ||
| < | less than | ||
| <= | less than or equal to (please note that there is no space between the two symbols) | ||
| < > | Not equal to (please note that there is no space between the two symbols) | ||
| = | equal to |
Functions
The following are the functional operators available while defining a formula:
| ABS | Absolute value of | ||
| LEAST | minimum of | ||
| GREATEST | maximum of | ||
| SUM | the total value of | ||
| ROUND | round to | ||
| TRUNC | integer part of | ||
| FLOOR | round off to the (lower) nearest | ||
| CEILING | round off to the (higher) nearest | ||
| POWER | to the power of | ||
| MOD | the remainder |
Using the building blocks discussed earlier, you can create or build formulae. You can build any number of formulae for a rule using the SDEs, UDEs and the results of formulae that you have defined for the rule.
The following example illustrates the procedure to create a formula.
IC rule is created with formula given below to calculate interest on overdraft account based on value dated balance.
| Formula no | Case | Result | Type | Cr/Dr | |||||
| 1 | DLY_NET_VD_BAL <0 | (OD_INTEREST_CALC/100)*(DAYS/YEAR) | Booked | Dr |
Interest product is created with the above mentioned IC rule and interest is applied on the overdraft account based on rate of interest maintained.
