5. Reports
This chapter deals with the various reports that are available for the Process framework.
5.1 List of Task Assignment Rules Report
5.1.1 Generating Task Assignment Rules Report
This report provide the list of rules for a given User ID and process flow. You can invoke this report by typing ‘ORRCACAR’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
Specify the following details:
From Date
Specify, from the adjoining calendar button, the date from which you require details.
To Date
Specify, from the adjoining calendar button, the date till which you require details.
Click ‘OK’ button to generate the report. Click ‘Exit’ to return to the Reports Browser.
5.1.2 Contents of the Report
The contents of the report are discussed under the following heads:
Header
The Header carries the Report Name, Run Date and Time and the Period for which the report is generated.
Body of the Report
The following details are displayed in the report:
Field Name Field Description
Process This is the process
Stage This is the stage of the process
Rule This is the rule ID
Rule Description This is the description of the rule
Expression This indicates the rule expression
Start Date This indicates the start date
End Date This indicates the end date
Disable This indicates whether the rule is disabled
Assignee User This is the user to whom the task is assigned
Execution Order This indicates the order of execution
5.2 Workflow Task Audit Log Report
5.2.1 Generating Workflow Task Audit Log Report
This report lists the workflow task assignment in chronological order. You can invoke the ‘Workflow Task Audit Log’ screen by typing ‘ORRCACAD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
From Date
To Date
5.2.2 Contents of the Report
Header
Body of the Report
Workflow Reference This is the workflow reference number
Event This is the event
Assignee Group This is the assignee group
Updated By This indicates the group or user who has updated the event.
Event Date This indicates the event date
Comments This indicates the comment
5.3 User Work Load Logically Grouped Based on Supervi­sor Report
5.3.1 Generating Work Load Report of the User
This report provides a list of open, closed and total number of tasks of direct reports of a supervisor. You can invoke this screen by typing ‘ORRCACLD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
From Date
To Date
Supervisor ID
Specify the supervisor ID. Alternatively, you can select the supervisor ID from the option list. The list displays all valid supervisor IDs.
5.3.2 Contents of the Report
Header
The Header carries the Report Name, Run Date and Time, Supervisor ID, User ID and the Period for which the report is generated.
Body of the Report
Total Task for the Period This indicates the total tasks during the specified period
User ID This is the user identification number
Pending Tasks This is the number of pending tasks
Completed Tasks This is the number of completed tasks
5.4 Assignment Vs Completed Analysis Report
5.4.1 Generating Assignment Vs Completed Analysis Report
This report lists tasks assigned to users and number of open, closed and total number of tasks. You can invoke the ‘Underwriting Status By Month and Intermediary Report’ screen by typing ‘ORRCACLD’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
From Date
To Date
Assignee Group
Specify the assignee group. Alternatively, you can select the assignee group from the option list. The list displays all valid assignee groups.
5.4.2 Contents of the Report
Header
The Header carries the Report Name, Run Date and Time, User ID, Assignee Group, Month for which report is being generated and the Period for which the report is generated.
Body of the Report
Total Task for the Period This number of tasks within the specified period.
Assignee Group This is the assignee group to which the task is assigned.
5.5 Load Factor Report
5.5.1 Generating Load Factor Report
This report lists the number of pending and completed tasks assigned to each user and and a load factor which indicates the percentage of group tasks assigned to user during the specified period. You can invoke this screen by typing ‘ORRCACLF’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
From Date
To Date
Assignee Group
Supervisor ID
5.5.2 Contents of the Report
Header
The Header carries the Report Name, Run Date and Time, Assignee Group, Month for which report is being generated and the Period for which the report is generated.
Body of the Report
Number of Ses­sions in the Period This indicates the number of sessions during the specified period
Peak Session Load This indicates the peak session load
Average Session Load This indicates the average session load
User This indicates the user ID
Total Number of tasks This indicates the total number of tasks
Peak Session This indicates the date and time of peak session
Pending Tasks This indicates the number of pending tasks
Completed Tasks This indicates the number of completed tasks
Percentage of Tasks Handles This indicates the percentage of tasks handled.
