This manual is designed to help you quickly get acquainted with Style Designer, a WSYWYG tool that helps you modify the look and feel the Oracle FLEXCUBE user interface.
The following abbreviations are used in this User Manual:
| Abbreviation | Description | ||
| CSS | Cascading Style Sheet | ||
| WYSIWYG | What You See Is What You Get |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized into the following chapters:
| Chapter | Description | ||
| Chapter 1 | About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual | ||
| Chapter 2 | Style Designer - An Overview provides a basic understanding of the style designer utility and its features | ||
| Chapter 3 | User Interface Elements chapter provides an overview of the various interface elements used by Oracle FLEXCUBE | ||
| Chapter 4 | Operations chapter explains the various actions that you can perform to change the look and feel of the interface elements | ||
| Chapter 5 | Deployment chapter explains how to integrate the CSS files modified by Style Designer into Oracle FLEXCUBE | ||
| Chapter 6 | Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
This User Manual may refer to all or some of the following icons.
| Icons | Function | ||
Exit | ||
Add row | ||
Delete row | ||
Option List |
