| Siebel CRM Configuring Siebel Open UI Siebel Innovation Pack 2016, Rev. A E52417-01 |
![]() Previous |
![]() Next |
View PDF |
Table B-4 describes the property sets that Siebel Open UI supports. Siebel Open UI uses the Handle Response
property set for navigation controls, such as the predefined query, drop down menus, screen tabs, and view tabs. Siebel Open UI handles the toolbar during setup because it does not dynamically update the property set.
Table B-4 Property Set Types That Siebel Open UI Supports
| Property Set | Description |
SWE_PROP_NC_PDQ_INFO |
Child property set for the Predefined Query (PDQ). It includes the list of PDQ items that Siebel Open UI displays. It uses the following properties:
SWE_PROP_NC_VISIBILITY_INFO |
Defines the beginning of the visibility property set. It uses the following properties:
You can use the VisDropDownItem property as the predefined bubbled handler to do user interface binding. |
SWE_PROP_NC_SCREENCTRL_INFO |
Defines information for the first level in a screen. It uses the all the same properties that the SWE_PROP_NC_VISIBILITY_INFO property set uses except it does not use the SWE_PROP_NC_ITEM_INFO property. You can use the GetTabInfo property as the predefined bubbled handler. |
SWE_PROP_NC_FLOATING_TAB_INFO |
If Siebel Open UI already displays a screen, and if the user clicks an empty tab, then SWE_PROP_NC_FLOATING_TAB_INFO adds a new tab. It uses the GetTabInfo property. |
SWE_PROP_NC_AGGREGATE_INFO |
Describes Amazon link information. It uses the GetTabLinkInfo property. It uses the following properties:
SWE_PROP_NC_SUBDETAIL_INFO |
Specifies information for the fourth level link. It uses the same properties that the SWE_PROP_NC_AGGREGATE_INFO property set uses. |
SWE_PROP_NC_DETAIL_INFO |
Specifies the view tab information that Siebel Open UI displays to start. It uses the GetTabInfo property. It uses the following properties:
You can use the following properties as predefined bubbled handlers:
