| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2016, Rev. C E52427-01 |
![]() Previous |
![]() Next |
View PDF |
When the server executes an insert transaction and the insert transaction fails, the insert-transaction failure can be handled in one of the following ways:
A record is logged that indicates the insert transaction failed, and synchronization continues. This is the default insert behavior. You can use the Conflict Administration screen to recover the data.
The insert-transaction failure is logged, including the details of the failure, and synchronization is interrupted. This is the FailOnError behavior. FailOnError behavior guarantees that if an insert transaction fails, then data loss does not occur since the synchronization is stopped and until the cause of the failure is resolved.
Note: If FailOnError processing takes place, then the synchronization is interrupted. The synchronization process continues to fail until the problem is resolved. Users must contact their system administrators to recover from the failure. The recovery effort can involve modifying transactions queued for processing, modifying data on the server, or reentering transactions through the Siebel Mobile disconnected application. |
You can enable the processing of insert-transaction failure globally or at the business component level when you configure the Siebel Mobile disconnected application. The following setting applies globally in the application: DefaultHandheldInsertMode. When FailOnError is specified, every failed insert-transaction interrupts synchronization.
To handle insert-transaction failures
Navigate to the Administration - Siebel Mobile screen, Application Administration, and then the Settings view.
Select the appropriate mobile application in the top applet.
In the Value field, specify the value for the DefaultHandheldInsertMode parameter by selecting one of the values shown in the following table.
| Value | Description |
| NoFail | Insert-transaction failures are logged, and the synchronization continues. This is the default behavior. |
| FailOnError | Insert-transaction failures are logged, and the synchronization ends. The system administrator must investigate to recover from this failure. For more information, see "Obtaining Error Details from Synchronization Sessions". |
You can also use the HandheldInsertFailMode user property to enable the processing of insert-transaction failures at the business component level.
Table 7-1 shows the combined effect of the DefaultHandheldInsertMode setting in the Settings view and on a business component. Note that the following conditions apply:
The business component setting always takes precedence over the settings defined in the Administration - Siebel Mobile, Application Administration, Settings view.
If there is no setting on a particular business component, then the Applications Settings value applies.
If there is no setting in either the Settings view or on the business component, then the default behavior is the same as NoFail. Insert-transaction failures are logged, and the synchronization continues.
In Table 7-1 the Tools Configuration column shows what DefaultHandheldInsertMode is equal to, and the Application Settings Value column shows the available application values. Reading down the first column in Table 7-1 and then from left to right, a NoFail business component setting in Siebel Tools combined with a FailOnError application setting results in the combined effect of NoFail.
Table 7-1 Combined Effect of Insert-Transaction Failure and the Settings
| Tools Configuration (User Property) | Application Settings Value: No Fail | Application Settings Value: FailOnError | Application Settings Value: Omitted |
NoFail |
NoFail |
NoFail |
NoFail |
FailOnError |
FailOnError |
FailOnError |
FailOnError |
No Setting on Business Component |
NoFail |
FailOnError |
NoFail |
Related Topics
"Defining the Settings for Processing Insert-Transaction Failure"
