| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
In certain screens, such as Projects, you can flag records that you want to single out. A flag acts as a reminder that only you can see.
To flag a record
Navigate to the record you want to flag.
In the Priority Flag field of the record, select the check box.
When you step off the record, a flag is placed in Priority Flag field.
The Priority Flag field is not available in all views. If you cannot see a Priority Flag field for the record, then check your Columns Displayed settings. For information about showing and hiding columns, see "Organizing List Columns".
