| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You might find that you want to change the width of a column so that you can see all of the data in the column. A changed column width is automatically saved, so you do not have to repeatedly resize the column.
To resize columns
Place the cursor over the right header divider for the column you want to resize.
A resize arrow appears.
Click and drag the column divider to the right to widen the column, or to the left to narrow the column.
