| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
By default, the Siebel Open UI client uses the Aurora theme as the user interface theme. Depending on your deployment of Siebel Open UI, other themes, such as the Synergy or Simplified User Interface (SUI) theme might be available. All themes generally have the same capabilities and you can modify the end user experience to match other application at a site. For more information about the Simplified UI theme, see "About the Simplified User Interface".
To set themes
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Behavior view.
The Behavior form appears.
Select the appropriate value from the drop-down list for the Theme field.
Note: The values available in the drop-down list depend on the value selected in the Navigation Control field. |
