| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can set a prompt to appear when deleting records asking for confirmation to delete the records.
To set the confirmation before deleting records prompt
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Behavior view.
The Behavior form appears.
Select the check box for the Confirm Before Deleting Record field.
