| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can view existing queries that you previously saved. For more information about queries, see Chapter 7, "Using Query to Locate Information."
To view a saved query
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Saved Queries view.
The Saved Queries list appears.
