| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can set up view links to appear in the view links area in screen home pages. For more information about the main elements in home pages, see "Home Pages for Screens".
If your Siebel administrator sets up view links for screen home pages and marks those links as public, then you cannot change or delete those links.
To add a view link to a screen home page
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the View Links view.
The Screen Homepages list appears.
In the Screen Homepages list, select the home page for which you want to add a view link.
If view links exist for the home page, then the View Links list shows those links.
In the View Links list, click the plus (+) icon.
Complete the fields as needed.
Some of the fields are described in the following table.
| Field | Description |
| Sequence | Type a number that determines the place of the link in the view links area of the screen home page. |
| Active | Select this check box to indicate this link is an active view link. |
| Name | Type a name for the link. |
| Description | Type a long description for the link. |
| View | Select a view in the Pick Screen View dialog box that appears when you click the select button in this field. |
| Default Query | Select a default predefined query for the view you select in the View field. |
