| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Task UI is a wizard-like user interface that:
Guides you through task execution.
Allows you to navigate back and forward during the task execution.
Allows you to resume or pause task execution at any point.
Task UI features help increase the efficiency of:
Novice or intermittent users by guiding them through the execution of unfamiliar tasks.
Experienced users who want to switch between multiple tasks throughout their workday.
Task UI includes the following features that support task execution:
Tasks Pane. The left side of the screen contains a listing of the tasks available to you. These tasks relate to the current context. When you select a given task, the Tasks Pane shows the sequence of steps for that task.
Navigation Buttons. The Task screen has a standard set of four buttons that control navigation through the task flow. It includes buttons to move forward and back through the task steps and provides the ability to pause a task for later resumption and to cancel a task. For more information about the navigational buttons, see "Navigational Buttons for Task UI".
Radio Buttons. Radio buttons provide support for decision-making within a task. The choices within a task determine the branches and screens that you can access.
After you launch a task item, it remains active until you complete it. If you launch Tasks, and navigate to a different screen, then the task items do not change. For more information about Task UI, see Siebel Business Process Framework: Task UI Guide.
