Siebel Hospitality Guide > Booking Hospitality Assets > About Hospitality Assets >
Automatic Reservation of Critical Assets
Critical resources are automatically reserved after the user creates a new Function line item or changes the line item quantity and saves the record. Critical resources also are reserved when a Function line item for a critical asset is copied or when the service start time is changed. If booking is unsuccessful for a critical resource, the status is changed to Not Available or Not Enough Assets. If changes are made to the function, such as a status change or a time change, then the asset inventory booking process is automatically started.
